Duet Shield Power Connections
Posted by HarveyC
June 07, 2015 06:29AM
Am I correct in beileving that the power for the Duet Shield is 12V and is taken from the spare connector block on the 5v Regulator Board?? As far as I can see, the instructions for the multi extruder upgrade do not mention the power connections at all.
Harvey
Re: Duet Shield Power Connections
June 08, 2015 08:16AM
Hi Harvey
Yes. The pictures here show it connected: [reprappro.com]
Thanks for pointing out that this isn't mentioned, I'll update the text to describe how the power should be connected.
Ian
RepRapPro tech support
Edited 1 time(s). Last edit at 06/08/2015 10:06AM by droftarts.
June 08, 2015 10:48AM
Thanks Ian, It's for the Mendel 3 upgrade actually, but there does not appear any other place to post this type of query about Duet (perhaps there should be a separate section?). I found the picture after I made the post.
Regards
Harvey
(Harry ... Hungerford)
