Web Interface 1.06 -collected data reporting problem June 09, 2015 06:09AM |
Re: Web Interface 1.06 -collected data reporting problem June 09, 2015 02:10PM |
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 05:08AM |
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 06:23AM |
appjaws1
@Darathy,
Thanks for that, this is the same for me I changed from zpl's to dc42's firware and then noticed the problems.
It must be a difference in the firmware versions that is causing this.
Lets hope it's fixed soon, I think dc42 is getting ready for a new release, whether this fix gets incorporated remains to be seen. He is a very busy man.
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 07:45AM |
dc42
Paul, can you try reverting to the official 1.09 release and see whether the problem is still present using the same print? I am not aware of any problems in that area, and my 1.09a release uses the same code as 1.09 for the print monitor apart from minor changes due to the interface for getting the extruder positions being different. I have 1.09b almost ready to be released.
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 08:07AM |
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 08:12AM |
Re: Web Interface 1.06 -collected data reporting problem June 10, 2015 06:39PM |
appjaws1
Thank you David,
If you want a pre release tested, let me know.
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 04:19AM |
dc42
You can try the binary at [dl.dropboxusercontent.com] if you like. I believe the problem is fixed. However, I notice that the web interface still shows the file as 100% complete for the first half minute or so of execution of a tool change macro file. It appears that when the printer returns status B to the web interface, meaning Busy (because it is executing a macro file), the web interface gives up asking the Duet for file progress information for half a minute or so and instead shows the print as 100% complete. PanelDue still shows the print progress correctly.
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 06:02AM |
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 07:02AM |
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 08:35AM |
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 12:27PM |
Re: Web Interface 1.06 -collected data reporting problem June 11, 2015 01:56PM |
appjaws1
Works great, thank you for your quick fix.
