Re: Printing axis Calibration 90 ABS problem on Z July 09, 2015 02:26AM |
Re: Printing axis Calibration 90 ABS problem on Z July 10, 2015 12:21PM |
Re: Printing axis Calibration 90 ABS problem on Z July 10, 2015 01:12PM |
Re: Printing axis Calibration 90 ABS problem on Z July 10, 2015 01:35PM |
Zonzo
Sorry for the stupid question, but HOW the heatsink have to fit on the Form232-tek/Joar's airduct???
Form232-tek
....This is not a print and play conversion. I have cut away 1/3 of the aluminium cooling ribs, and drilled a new hole in it. The cooling rib is also rotated 90 deg. Since the plastic is fairly close to the hot end, I have also made a small heat shield between the hot aluminium and the plastic. A small hole in the plastic cools down the heat shield.
Re: Printing axis Calibration 90 ABS problem on Z July 10, 2015 03:33PM |
Re: Printing axis Calibration 90 ABS problem on Z July 10, 2015 03:55PM |
Treito
As I really like the design of the fan in theory (not printed yet) I will look how to make an adapter for both - the hotend and the sensor. I think of an adapter plate between one fan side and the airduct. I think on monday there could be results. I hope you have enough patience.
Re: Printing axis Calibration 90 ABS problem on Z July 11, 2015 03:13AM |
ormerod168
but lucky me got two printers, will keep it on one of them for PLA print...and eye candy, it's a real crowd pleaser :-)
Re: Printing axis Calibration 90 ABS problem on Z July 19, 2015 06:57AM |
Re: Printing axis Calibration 90 ABS problem on Z July 19, 2015 07:22AM |
ormerod168
zombiepantslol
You have this "M203 X6000 Y6000 Z500 E3000 ; Allow 100mm/s speeds" in your start G-code but you don't need it, it actually slows down some moves...
that may be true with the axises but slows down the extruder so I'll keep the M203 E3600 string
Erik
M201 X1000 Y1000 Z15 E1000; acceleration tweaks for improved finish M203 X15000 Y15000 Z150 E3600; speed tweaks for improved finish
Re: Printing axis Calibration 90 ABS problem on Z July 19, 2015 07:50AM |
Treito
I had to slow down my z-axis as it squeezes very loud otherwise and I am not able to find the source. So what is wrong about this:
M201 X800 Y800 Z15 E3600 ; Accelerations (mm/s^2) M203 E3600 ; Maximum speeds (mm/min)
Re: Printing axis Calibration 90 ABS problem on Z July 19, 2015 08:01AM |
