Re: E3D V6 June 18, 2015 05:35PM |
Re: E3D V6 June 18, 2015 05:47PM |
Re: E3D V6 June 18, 2015 07:30PM |
Re: E3D V6 June 19, 2015 08:25AM |
dc42
I have just installed an E3Dv6 in my Duet-powered Kossel, so I can tell you that you need to set the B parameter in the M305 P1 command in config.g to 4267. Despite the heater being only 25W power, it heats up very quickly and the temperature overshoots (I guess that shows how good the thermal break is). So I will be reducing the S factor in that M305 command too.
Re: E3D V6 June 19, 2015 10:40AM |
Darathy
dc42
Thank you, it will work on your probe with no modifications?
Re: E3D V6 June 19, 2015 11:01AM |
Re: E3D V6 June 19, 2015 11:07AM |
Re: E3D V6 June 19, 2015 11:14AM |
ezwul
I noticed that the cooling section with the fins of the E3D clone that I bought from China via ebay is longer, and didnt allow it to be assembled to the mounts published on thingiverse and the forums.
So I advise verify the dimensions of your E3D against the design before wasting plastic printing a part that will not fit.
Re: E3D V6 June 19, 2015 12:18PM |
Quite happy to design my own mount, just worried that others mught get caught as well.
Re: E3D V6 June 19, 2015 12:24PM |
Re: E3D V6 June 19, 2015 01:31PM |
Treito
So I am excited what I will get. How can I seperate the two versions?
Re: E3D V6 June 19, 2015 01:42PM |
dougal1957
To the best of my knowledge E3D themselves only do the V6 now and if you might want to go multi extruder anytime then the E3D Chimera is probably the way to go it is tiny.
Doug
. The parts are not here yet. I bought it at a website where the risk of false part is pretty high.|
Re: E3D V6 June 19, 2015 02:22PM |
Re: E3D V6 June 19, 2015 02:56PM |
Re: E3D V6 June 19, 2015 03:15PM |
Re: E3D V6 June 20, 2015 07:45AM |
Re: E3D V6 June 20, 2015 08:30AM |
dc42
Has anyone using the E3D on the Ormerod got high-quality prints with it yet? Since I changed over to it on my delta, I've been getting a lot of very small blobs on the print. The same test print on the Ormerod, and on the delta while it still had the Jhead, is much better. I've tried lower temperature, higher temperature, 6mm retraction (as used on the Jhead), and 2mm retraction (maximum recommended by E3D), all to no avail.
Re: E3D V6 June 20, 2015 09:25AM |
dc42
Re: E3D V6 June 20, 2015 09:27AM |
Darathy
dc42
M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction ,you mean this? or should i add another M305 line?
Re: E3D V6 June 20, 2015 09:41AM |
Re: E3D V6 June 20, 2015 02:39PM |
dc42
Re: E3D V6 June 21, 2015 03:21PM |
Re: E3D V6 June 21, 2015 04:23PM |
Darathy
Well i have made a huge mistake.... the person who designed the mounts designed his own X.home pad which he failed to include in the Stl's. Silly me printed Dc's sensor pad and only after asembeling i notice the sensor is lower then the pad...
[attachment 56966 IMAG0256.jpg]
Now my question is for DC42: Do i turn the Original Hot end away from the new air duct or keep it like it is? It is verry close to the fan duct and it will most probably melt it like you see in the picture:
[attachment 56967 IMAG0257.jpg]
Should i turn the aluminum part to other side?
Also i have recived a part i dont know if it is soposed to be used in my E3D:
[attachment 56974 IMAG0258.jpg]
Looks like pneumatic fiting type for bowden but it is much too big for my hot end.
Excuse the messy table! xD
Re: E3D V6 June 21, 2015 04:33PM |
Darathy
Darathy
Re: E3D V6 June 21, 2015 04:50PM |
Re: E3D V6 June 21, 2015 05:17PM |
Re: E3D V6 June 21, 2015 09:12PM |
Re: E3D V6 June 22, 2015 01:55AM |
Re: E3D V6 June 22, 2015 02:46AM |
dc42
I remember now, the clearance is rather tight at the sides; but that's still the way I had it round.
