E3D V6
Posted by Darathy
Re: E3D V6
June 25, 2015 03:53PM
ok i have my E3D mounted and ready ,but i have 1 small problem i have set it to 195C it heats up slowly and then settles at 196C for a while then slowly goes down to 195. I am guessing firmware does not support M303 for PID auto tuning? How do i calibrate PID?
Re: E3D V6
June 25, 2015 06:45PM
Can you post a graph of your hot end temperature?
Re: E3D V6
June 26, 2015 04:32PM
I find it ok if it overshots it by 1C but i feel like it heats up a lot slower then the original Ormerod hot end. Anyway to increase the speed?
Also if anyone will be printing that E3D mount here is a Sensor pad i designed for DC's sensor
Edited 4 time(s). Last edit at 06/26/2015 04:38PM by Darathy.
open | download - Sensor Pad.STL (47.3 KB)
Re: E3D V6
June 26, 2015 05:04PM
Looks to me like it's flattening off a little too early. If you are using the default PID parameters, try increasing the S term to 1.1 or 1.2, or the I term to 0.1 or 0.2 in the M301 H1 command (add that command if you don't already have it in config.g).
The heater in the E3D is only 25W, so it may be a little slower heating than the Ormerod hot end.
Edited 1 time(s). Last edit at 06/26/2015 05:05PM by dc42.
Re: E3D V6
June 27, 2015 05:49AM
I've just done some investigation, and it looks to me that although E3D say you should use a B value of 4267 in RepRapFirmware for the thermistor they supply, a value of 4388 will give more accurate temperature readings. I will shortly start a new thread on thermistor B values.
Re: E3D V6
June 28, 2015 06:46AM
Thank you for looking into it. Now it seems i get a diferent problem seems like at start of the print when the hot end is heating i get a temp error showing at random.I havent had it do it during printing but during Heating up i had it a few times now. Any ideas what might be cousing it?
Re: E3D V6
June 28, 2015 07:16AM
Darathy
Probably a loose thermistor connection. Perhaps you didn't squeeze the crimps tight enough. Or possibly an intermittent short between one of the thermistor wires and the heater block.
Re: E3D V6
July 03, 2015 04:42PM
dc42
Darathy
I redid the Crimps i squized them as tight as i could. Checked the hermistor wires in the heater block they looked covered to tip with the fiberglass. I still get error when print is heating up to temperature and only then, i have had several hour long prints with no errors during those prints. Any more ideas what to check? i am also using on of your Dual nozzle Sensor boards which i installed at the same time as the E3D
Edited 1 time(s). Last edit at 07/03/2015 04:44PM by Darathy.
Re: E3D V6
July 04, 2015 07:42AM
It could be caused by a bad crimp connection on one of the wires connected to the hot end board. Have you tried waggling them, to see if you can induce the fault?
Re: E3D V6
July 04, 2015 07:56AM
yes i did try in all directions with diferent forces .but i cant reproduce the error.
Re: E3D V6
July 04, 2015 10:41AM
on the other note i have printed 3D Benchy with E3D V6 and i can confirm dc42s problem ,it does seem to make blobs at the layer starting positions retraction didnt seem to help:
I also have ringing issues araund the holes and on 1 side of door.
The green/pink one is printed with Ormerod stock nozzle with no obvius blobs or layer starting positions.
Edited 1 time(s). Last edit at 07/04/2015 10:43AM by Darathy.
Re: E3D V6
July 09, 2015 02:45PM
I must say i am a little disapointed in Quality i'm getting with E3D ,i expected something a lot better ,i think my Original Ormerod hotend was printing better or its just the diference in 0.5 and 0.4 nozzles , the 0.4 nozzle just doent seem to be able to do overhangs as well as 0.5 and i'm getting blobs on my prints aswell.
Re: E3D V6
July 09, 2015 03:12PM
Or maybe it is just only some wrong slicing settings?
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
Re: E3D V6
July 09, 2015 04:45PM
I get those blobs when I slice with Slic3r. When I slice with Cura, they go away. If you want, I can post my Cura settings file tomorrow, if you want to give it a shot with Cura.
Re: E3D V6
July 09, 2015 05:27PM
I am coming to the opinion that the E3Dv6 is less suited to Bowden extruders that the RepRapPro hot ends on my Ormerod 1 or the J head that I had on my delta originally. I am considering using either an E3D lite or a RepRapPro hot end on my delta.
Re: E3D V6
July 09, 2015 06:36PM
I've been very happy with my e3d v6 for ABS printing on the O2. Attempts to work with pet-g though.. have been consistent failures.
Re: E3D V6
July 13, 2015 07:38PM
ABS, 0.2mm layers @235C
0.8mm perimeters (likely the cause of deformation area in the bow, an earlier print with 1.2mm walls did not suffer this)
1.6mm retraction
Sliced with Cura.
Edited 1 time(s). Last edit at 07/14/2015 12:20PM by achaz.
Re: E3D V6
July 14, 2015 12:49AM
What do you use as bed surface?
Re: E3D V6
July 14, 2015 09:00AM
kapton on glass.
Re: E3D V6
July 15, 2015 03:16PM
i do see a lot of blobs on your prints too ,altho overall print quality is very nice. I have found the main problem with most of my prints which was Slic3r 1.2.0 onwards to 1.2.9 ,i'm trying with 1.1.7 and it makes much better look quaility but does not completely fill gaps and has a much less efficient moves. I hope they fix the problem with slic3r soon.
Edited 1 time(s). Last edit at 07/15/2015 03:18PM by Darathy.
Re: E3D V6
July 15, 2015 03:35PM
a little blobbing yes, extrusion and retraction fine tuning isn't really my thing, and most of what I print will either have some additional fitting work done anyways (so no problem to clean up a little nubbin on a vertical seam), or will be parts for model combat warships (see rcwarshipcombat.com ) and a little blob isn't a big deal there.
Overall I feel my quality and consistency of print and precision is much better with the e3d. For me a little blobbing (and it isn't as bad as the photos make it look) is no problem. I do think that everyone has to decide what is best for their own needs though, and if blobs are a problem, the e3dv6 may not be a good pickup.
This was the first thing I printed that wasn't a calibration angle or cube after installing the e3d:
I had a few extruder feed problems but overall the result was great compared to what I had been getting off the printer previously which i felt tended to turn everything a bit melty from the nozzles radiant heat.
I've been reasonably happy with Cura (at least until their latest beta release), my biggest gripe has been the support structure and trying to get it to generate support for thin items. You might try Cura 15.x and see if it gets you better results than slic3r.
Edited 2 time(s). Last edit at 07/15/2015 03:41PM by achaz.
Re: E3D V6
July 15, 2015 03:46PM
What i dont like abaut cura is it hard to calibrate anything ,most holes are way too small .while with slic3r i can change almost evrything and get really good hole sizes. I was printing this [www.thingiverse.com] and nothing fitted together ,while with slic3r it did. But cura makes a better support structure and fails to save settings and plugins(not to mention it cant replace existing cura version and i have to remove it by hand) with new releses . I am seriusly thinking of buying Simplify3D ,i've been hearing lots of good things abaut it but the cost is damn expensive....
Edited 1 time(s). Last edit at 07/15/2015 03:47PM by Darathy.
Re: E3D V6
July 15, 2015 04:28PM
Yeah, I can't bring myself to buy S3d either.
The too small-hole thing got better for me after I switched to the e3d, not sure why, but I'm guessing since the Ultimaker ships with a 0.4mm nozzle maybe it internally does some things better for that size than the 0.5? The new beta release of Cura exposes a lot of the underlying settings for adjustment, but I really don't like the UI so haven't played with it much yet.
That ballista is pretty slick, going to have to queue that up
Re: E3D V6
July 15, 2015 06:04PM
So heres the diference between slic3r 1.2.9 and 1.1.7:
Printed an Arm for [www.thingiverse.com] with same settings for both.
1.2.9:
Sorry i did not disasemble the quad to show you how it looks on the inside.
1.1.7:
(with 1.2.9 the middle part was really messy with overextrusion eventho i have it set to underextrude by a lot)
(it did not fill the small holes where as 1.2.9 does fill them)
Something strange happaned with slic3r after 1.1.7 which couses overextrusion and i hope it gets fixed.
Edited 2 time(s). Last edit at 07/15/2015 06:07PM by Darathy.
Re: E3D V6
July 15, 2015 07:16PM
Hey you have the same mice.
Slic3r 1.2.x got some new settings. As I did not experince problems like this and for me the quality is much better I still think that some of the new settings are causing this and it is only a problem with your configuration. Maybe you can post a g-code file or at least the parts showing your set up.
Re: E3D V6
July 16, 2015 12:35PM
Dont know i have come across a post several pages long of poeple having the same problem and i tested it. I will look into settings if i can change anything.
The mouse is gona be replaced soon, the middle scrollwheel is worn out and it makes my scrolling a nightmare.
Re: E3D V6
August 29, 2015 08:43AM
I have reverted back to Original Nozzle finding it providing a much better print quality then the E3D sad smiley ,now have a spare E3D laying araund. Mybe i will make a delta will see smiling smiley
My personal experiance i dont recomend anyone to upgrade to E3D, but thats just my experiance smiling smiley
Edited 1 time(s). Last edit at 08/29/2015 08:43AM by Darathy.
Re: E3D V6
August 29, 2015 10:57AM
But you had the original one, hadn't you?
I cannot imagine, why your print was not getting better. It would have been nice if you could show us pictures where we can compare your problem. Probably it is only a setting. Or maybe it is the heating cartridge so the Duet is not able to compensate temperature drops during the print. One of thousand possibilities.
Re: E3D V6
August 29, 2015 01:37PM
Ive managed to get pretty decent prints, but on round parts(like a bigger hole) the outside perimiter would not stick to the previous layer so i had a lot of strings inside the hole. But im back to stock hot end and the print quality is better.
Re: E3D V6
August 29, 2015 02:39PM
Someone else having the same problem with S3D. Go here to find their forum suggestions to solve the problem: Blobby problems with ormerod and Simply3D
