Got problem about the slic3r setting June 19, 2015 09:53AM |
Re: Got problem about the slic3r setting June 19, 2015 10:12AM |
Re: Got problem about the slic3r setting June 20, 2015 01:14AM |
Re: Got problem about the slic3r setting June 20, 2015 06:34AM |
; filament_diameter = 3
Re: Got problem about the slic3r setting June 20, 2015 08:51AM |
Re: Got problem about the slic3r setting June 22, 2015 07:47AM |
Re: Got problem about the slic3r setting June 22, 2015 08:17AM |
Re: Got problem about the slic3r setting June 22, 2015 08:51AM |
jhlee1994
Hi sir, about the raft and support material what is the correct setting if it? And what does the skirt for?
Printing problem June 23, 2015 11:32AM |
Re: Printing problem June 23, 2015 12:36PM |
jhlee1994
Hi sir, I'd print 2 object the top view is ok but the below surface which is contact with raft and support material wasn't very good quality and have very rough first layer. How can I solve this problem?
Re: Printing problem June 24, 2015 12:20AM |
Re: Printing problem June 24, 2015 08:26AM |
jhlee1994
Hi sir, so in what situation raft and support material are need and in what situation they are no need?
Re: Printing problem June 24, 2015 11:04AM |
Re: Printing problem June 25, 2015 08:06AM |
jhlee1994
Hi sir, how to set the cura for the bed setting. I'd convert the stl to gcode and upload it to my printer but from my printer interface the printing object was printed at the corner of the bed.. How can I set it to the center point of my heat bed?
Re: Printing problem June 25, 2015 11:26AM |
Re: Printing problem June 25, 2015 12:24PM |
jhlee1994
Why i got this word appear when I was printing :"Setting bed temperature to 56.000000 degrees Celsius.
Setting hotend temperature to 200.000000 degrees Celsius.
Error: invalid M Code: M117 Printing..." After that the printer will stop.
Re: Printing problem June 26, 2015 03:55AM |
Re: Printing problem June 26, 2015 07:30AM |
jhlee1994
So you mean my temperature setting wasn't match with the setting on the gcode, so the M117 massages was come out isn't it? All I know is I'd set 210 degree Celsius for tool. 60 for heat bed on the cura. But I was setting 200 for tool and 56 for heatbed in the printer interface. So was it this causing the problem?
Re: Printing problem June 26, 2015 11:34AM |
Re: Printing problem June 26, 2015 11:35AM |
Re: Printing problem June 26, 2015 12:11PM |
Re: Got problem about the slic3r setting June 26, 2015 01:05PM |
Re: Printing problem June 27, 2015 11:38PM |
Re: Got problem about the slic3r setting June 28, 2015 05:31AM |
Re: Printing problem June 28, 2015 07:47AM |
Re: Printing problem June 28, 2015 08:24AM |
Re: Printing problem June 29, 2015 01:22AM |
Re: Printing problem June 29, 2015 02:06AM |
Darathy
i think so, i think it mainly enables Relative extruder moves and retraction per layer change. but you will have to apply it evrytime you update cura(since it can not upgrade its previus version -.-, atleast slicer keeps configs after you update...)
Re: Printing problem June 29, 2015 02:49AM |
jhlee1994
How can I apply the setting to my cura? i'd try a lot of time but still don't get it.
