Re: Printing problem June 29, 2015 03:05AM |
Re: Printing problem June 29, 2015 03:16AM |
Re: Printing problem June 29, 2015 05:01AM |
Re: Printing problem June 29, 2015 06:16AM |
Re: Printing problem June 29, 2015 06:45AM |
Re: Printing problem June 29, 2015 07:39AM |
Re: Printing problem June 29, 2015 07:40AM |
thank you I forgot to write how to instal itQuote
ormerod168
jhlee1994
How can I apply the setting to my cura? i'd try a lot of time but still don't get it.
Copy the EAtoR.py to your (e.g. on my system) C:\Program Files (x86)\Cura_15.04\plugins, start the program, go to plugins, highlight the "extrustion to relative Ormerod RepRapPro" plugin and press the ad button
[attachment 57262 curaadplugin.JPG]
open the cura start/end-Gcode menu, chose the start code, copy over the text from your slic3r settings start code
[attachment 57263 curastartcode.JPG]
ditto end Gcode
[attachment 57264 curaendcode.JPG]
Erik
Re: Printing problem June 29, 2015 08:27AM |
Re: Printing problem June 29, 2015 09:34AM |
Re: Printing problem June 29, 2015 11:41AM |
Re: Got problem about the slic3r setting June 29, 2015 11:58AM |
Re: Printing problem June 30, 2015 04:53AM |
Re: Printing problem June 30, 2015 04:59AM |
Re: Got problem about the slic3r setting June 30, 2015 07:28AM |
Re: Got problem about the slic3r setting June 30, 2015 12:06PM |
Re: Got problem about the slic3r setting July 02, 2015 06:14AM |
Re: Got problem about the cura slic3r setting July 02, 2015 06:18AM |
Re: Got problem about the slic3r setting July 02, 2015 08:49AM |
Temperature problem while printing using ABS July 02, 2015 09:19AM |
Re: Got problem about the slic3r setting July 02, 2015 09:23AM |
Re: Got problem about the slic3r setting July 02, 2015 09:30AM |
Re: Got problem about the slic3r setting July 02, 2015 09:33AM |
Re: Got problem about the slic3r setting July 02, 2015 09:48AM |
Re: Got problem about the slic3r setting July 02, 2015 01:43PM |
jhlee1994
Sir, I think the problem is pretty obvious at my cura setting. I put other stl file at it, it still the same. infill still at outside.
Re: Got problem about the cura slic3r setting July 02, 2015 02:30PM |
jhlee1994
And here is the firmware. the config.g also inside this folder
Printing problem with ABS July 03, 2015 11:31AM |
Re: Printing problem with ABS July 03, 2015 11:58AM |
jhlee1994
So you mean I should put a piece of cardboard or foam at the top of the glass printing surface until the temperature reach 110 degree Celsius. I think my heat bed max is 100+ but need quite long time. At the printing the temperature keep dropping, this is the big problem. I always need to pause and heat up the heat bed. then I can continue. This was delay my finishing time
Re: Printing problem with ABS July 04, 2015 04:26AM |
Re: Printing problem with ABS July 04, 2015 04:30AM |
Re: Printing problem with ABS July 04, 2015 05:58AM |
