Re: Got problem about the slic3r setting July 05, 2015 09:18AM |
Re: Printing problem with ABS July 11, 2015 04:31AM |
Re: Printing problem with ABS July 11, 2015 06:42AM |
jhlee1994
Was it the ormerod 1 got feature to insulate the heat? I think this heatbed got design some feature for it. And now I'd observe that my bed supporter which is made by wood was sinking. Was it that got do with the bed insulate heat?
Re: Printing problem with ABS July 12, 2015 02:56AM |
Re: Printing problem with ABS July 12, 2015 03:01AM |
Re: Printing problem with ABS July 13, 2015 03:14PM |
Re: Printing problem with ABS July 14, 2015 11:26AM |
Re: Printing problem with ABS July 14, 2015 12:10PM |
jhlee1994
I'd apply a layer of aluminium foil it's performance better already maximum can reach 90 degree. I think the aluminium foil wasn't heavy duty...
..or can I just change my power supply into 13V? But I'm afraid the arduino got burn off
Re: Printing problem with ABS July 15, 2015 11:36PM |
Slic3r setting problem July 17, 2015 08:04AM |
Re: Slic3r setting problem July 17, 2015 10:40AM |
jhlee1994
For the slic3r 1-2-9 version there is contact z distance in the print setting, what should I put for this? 0.2 the support material will be detachable to the object..
Now I'm facing the problem is I'm printing a tube so inside the tube hole got the support material, but it's attached to the inner surface. I can't remove it
Cura setting problem July 18, 2015 10:40AM |
Re: Cura setting problem July 19, 2015 10:28AM |
Re: Cura setting problem July 19, 2015 02:16PM |
jhlee1994
Was it my setting in the machine setting went wrong? would you check and guide me.
Re: Got problem about the slic3r setting July 20, 2015 03:22PM |
M111 S0; Debug off M550 POrmerod168 ; Machine name (can be anything you like) M551 Preprap ; Machine password M552 P192.168.1.14 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates M83 ; relative extruder moves M906 X1000 Y1200 Z800 E1200 ; Set motor currents (mA) M563 P0 D0 H1 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 E420 ; Set extruder steps per mm M558 P1 ; Use an unmodulated Z probe or an intelligent Z probe G31 Z0.75 P500 ; Set the probe height and threshold (put your own values here) M201 X800 Y800 Z15 E3600 ; Accelerations (mm/s^2) M556 S78 X0 Y0 Z0 ; axis compensation M203 E3600 ; Maximum speeds (mm/min) M566 X1800 Y1800 Z30 E20 ; maximum jerk speed mm/minute(i.e. maximum instantaneous change in speed) M208 X210 Y205 ; set axis travel M208 X 0 S1 ; set axis minimum M574 X0 Y2 Z0 S1 T0
Re: Slic3r setting problem July 26, 2015 04:53AM |
Re: Slic3r setting problem July 27, 2015 09:36AM |
jhlee1994
I got some trouble at printing using slic3r. Sometimes the filament can't come out and extruder just keep extruding
Re: Slic3r setting problem July 27, 2015 11:55PM |
Re: Slic3r setting problem July 28, 2015 03:41AM |
Re: Got problem about the slic3r setting July 28, 2015 10:10AM |
Re: Slic3r setting problem July 30, 2015 04:37AM |
Re: Slic3r setting problem July 30, 2015 06:39AM |
Re: Got problem about the slic3r setting July 30, 2015 11:49AM |
Re: Slic3r setting problem July 31, 2015 01:37AM |
Re: Slic3r setting problem July 31, 2015 04:31AM |
Re: Slic3r setting problem July 31, 2015 07:08AM |
jhlee1994
But I can't set the bed temperature at the slic3r setting or it'll take a long time to heat plus the temperature can't stable at 110 degree it'll drop after a while. this keep bothering me while I need to print big part. Now the small part wasn't a issue. But the bigger one. I post the file to you better for you to understand. This is the file I want to print but due to the heat problem, it can't print the first layer finish before the temp drop till below 100 degree
Re: Slic3r setting problem July 31, 2015 09:30AM |
Re: Slic3r setting problem July 31, 2015 09:42AM |
Re: Slic3r setting problem July 31, 2015 10:10AM |
jhlee1994
... Can the duet can stand 14V? last time the instruction tell not to go more than 13.5V. I also afraid it got burn off. I'd experience once, It's quite messy but I'd manage to repair it up.
Re: Slic3r setting problem July 31, 2015 12:46PM |
