New experimental firmware 1.09c-dc42 June 26, 2015 04:57PM |
Fixed two potential divide by zero errors in PrintMonitor
No longer reports an error if a tpre, tpost or tfree macro file is not found
Changed the way bed height errors are reporting after bed probing without calibration (i.e. with parameter S-1 on the final G30 command)
Final Z probing speed is now always 1/3 of the initial probing speed as set by M210 instead of the Z jerk speed
Bug fix: after Z probing, the Z height was set incorrectly by 1 motor microstep, which affected delta calibration
Updated homedelta.g file to use slower final homing and faster positioning after homing
Re: New experimental firmware 1.09c-dc42 June 28, 2015 11:55AM |
Re: New experimental firmware 1.09c-dc42 June 28, 2015 12:51PM |
Re: New experimental firmware 1.09c-dc42 June 28, 2015 03:58PM |
Re: New experimental firmware 1.09c-dc42 June 28, 2015 05:19PM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 02:49AM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 03:21AM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 04:23AM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 05:46AM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 07:34AM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 12:07PM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 01:19PM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 02:00PM |
Re: New experimental firmware 1.09c-dc42 June 29, 2015 03:18PM |
Re: New experimental firmware 1.09c-dc42 June 30, 2015 02:15AM |
Re: New experimental firmware 1.09c-dc42 June 30, 2015 04:40AM |
dc42
I've released version 1.09c of my firmware fork at [github.com]. Changes since 1.09b are:
The recommended web interface is still DuetWebControl 1.06.
Re: New experimental firmware 1.09c-dc42 June 30, 2015 05:58AM |
Re: New experimental firmware 1.09c-dc42 June 30, 2015 06:01AM |
dc42
The official purpose of M210 is to set the homing speeds in mm per minute, e.g. M210 X1000 Y1000 Z100. But RepRapFirmware defines the homing speeds in the homing files instead. So the only value that matters is the Z value. This is used as the Z probing speed.
The order of commands in config.g mostly doesn't matter, except that the M563 tool definition commands must come before any commands that manipulate tools such as G10 and T0.
Re: New experimental firmware 1.09c-dc42 June 30, 2015 06:17AM |
Re: New experimental firmware 1.09c-dc42 June 30, 2015 06:30AM |
Re: New experimental firmware 1.09c-dc42 July 03, 2015 02:05PM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 04:11AM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 05:30AM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 06:40AM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 07:14AM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 12:54PM |
Re: New experimental firmware 1.09c-dc42 July 04, 2015 01:05PM |
dmould
Thanks - seems that David's github branch does not have the "download zip" option. For me, transferring the www folder to the SD card is still easiest carried out by removing the card.
I quite like the new (for me) web design in 1.06. The only very slight niggle is that it no longer shows "last layer time" - that appears to have been replaced by "first layer time". It was occasionally handy to know how long the last layer had taken to print, but I don't have a use for knowing how long the first layer took - but no big deal, I can get an approximation from the graph when I need it.
Dave
Re: New experimental firmware 1.09c-dc42 July 05, 2015 07:06AM |
dmould
Re: New experimental firmware 1.09c-dc42 July 05, 2015 09:25AM |
Re: New experimental firmware 1.09c-dc42 July 06, 2015 12:35AM |
