Hot end thermistor B values in M305 command June 27, 2015 06:45AM |
Re: Hot end thermistor B values in M305 command June 28, 2015 05:09AM |
Re: Hot end thermistor B values in M305 command June 28, 2015 07:19AM |
achaz
Very interesting, thanks for digging in to this.
As someone who has purchased and installed an e3d with the Semitec 104gt-2 and prints with mostly materials in the 230 -250 range, should i at minimum switch the B value to 4388?
Re: Hot end thermistor B values in M305 command June 28, 2015 12:03PM |
Re: Hot end thermistor B values in M305 command July 09, 2015 02:31PM |
dc42
Sadly, after searching the truly awful Honeywell Sensing web site, I was unable to find any data at all for the 135-104QAD-J01 thermistor used in the RRP hot end. However, the B value quoted for a related thermistor in the same range is for 25C and 85C. So the readings from that thermistor are also likely to be some way out at printing temperatures.
Re: Hot end thermistor B values in M305 command July 09, 2015 05:16PM |
Treito
dc42
What about this page?
[www.digikey.de]
Re: Hot end thermistor B values in M305 command July 29, 2015 09:12AM |
Re: Hot end thermistor B values in M305 command July 29, 2015 09:20AM |
roboprint
David, can you provide your actual M305 P1 line for E3D v6 hotend?
Re: Hot end thermistor B values in M305 command July 30, 2015 06:18PM |
dc42
M305 P1 T100000 B4388 R4700 H0 L0
Change R4700 to R1000 if your Duet is an older one with 1K series resistors. Change H0 to whatever you need to get the correct reading at room temperature (mine needs H30).
Re: Hot end thermistor B values in M305 command July 30, 2015 07:42PM |
roboprint
Replikeo's duet boards coming with 1K resistors.
Re: Hot end thermistor B values in M305 command July 31, 2015 03:04AM |
Treito
Even the new ones? With the 5V power PCB included? Good to know... BTT: The chinese E3D replica and the most buyable thermistors (ebay, Replikeo, Robotdigg) seems to have a B-value of 3950 at 100k.
Re: Hot end thermistor B values in M305 command July 31, 2015 04:29AM |
