Duet Board failure? July 08, 2015 07:59AM |
Re: Duet Board failure? July 08, 2015 08:13AM |
Re: Duet Board failure? July 08, 2015 08:22AM |
Re: Duet Board failure? July 09, 2015 02:37AM |
Re: Duet Board failure? July 09, 2015 08:19AM |
smoothboy
Thank you for the answer. I tried out the X Y stepper motor swapping test and it conduced to an object with the error in the X direction! So, unfortunately, as I suspected, it is a Duet board failure due to a movement of the Y by hand. Is it possible some kind of fix on the board or I have to change it with a new one? I do have an Omerod 1; Is the Duet Board currently available compatible?
Pay attention moving the stepper motors by hand because it can result in a Duet board damage! :-(
Rick.
Re: Duet Board failure? July 09, 2015 09:37AM |
smoothboy
Rick.
Re: Duet Board failure? July 09, 2015 10:21AM |
Re: Duet Board failure? July 09, 2015 11:57AM |
Re: Duet Board failure? July 09, 2015 05:23PM |
Re: Duet Board failure? July 10, 2015 02:05AM |
Re: Duet Board failure? July 18, 2015 08:37AM |
Re: Duet Board failure? July 18, 2015 10:49AM |
Re: Duet Board failure? July 19, 2015 08:45AM |
Re: Duet Board failure? July 20, 2015 07:33AM |
dc42
Let me know whether you manage to change the chip. I have an SMD rework station and a spare A4982, but I haven't needed to replace a driver chip yet. Getting the old one off shouldn't be too hard, but soldering the new one on may be tricky because of the thermal pad. I suspect it would be better to to heat the board from the underside using hot air, rather than heat the new chip from the top.
Re: Duet Board failure? July 20, 2015 09:37AM |
Re: Duet Board failure? July 21, 2015 07:54AM |
smoothboy
Dave,
do you apply heat from the big soldering iron on top of IC to be solder or on the back of the p.c.b.?
Thank you.
