Ormerod 1 software upgrade July 19, 2015 07:07AM |
Re: Ormerod 1 software upgrade July 19, 2015 07:18AM |
Re: Ormerod 1 software upgrade July 19, 2015 07:28AM |
Re: Ormerod 1 software upgrade July 19, 2015 08:02AM |
GregL
Three issues found so far
1. X axis does not zero properly - the sensor does not go to the nice white (now off-white) patch set for it
2. The Nozzle heater (heater 1) does not set temperature - but I can get its temperature up by setting the 'standby' temp.
3. Absolutely no movement in the extruder
Any help would be gratefully received.
Greg
Re: Ormerod 1 software upgrade July 19, 2015 08:35AM |
Re: Ormerod 1 software upgrade July 19, 2015 08:59AM |
Re: Ormerod 1 software upgrade July 19, 2015 09:05AM |
Re: Ormerod 1 software upgrade July 19, 2015 09:20AM |
Re: Ormerod 1 software upgrade July 19, 2015 09:29AM |
ormerod168
GregL
Greg
Hi Greg
A lot of things have change since version 0.65, AFAIR tool numbering, probe cabling, X-motor reversed mechanically or set so in config - you got some reading do do :-)
RepRapPro notice: Change of tool number
[forums.reprap.org]
Experimental firmware 0.78a-dc42
[forums.reprap.org]
Erik
Re: Ormerod 1 software upgrade July 19, 2015 11:30AM |
Re: Ormerod 1 software upgrade July 19, 2015 01:40PM |
Re: Ormerod 1 software upgrade July 20, 2015 09:00AM |
Re: Ormerod 1 software upgrade July 21, 2015 06:27AM |
Re: Ormerod 1 software upgrade July 24, 2015 09:08AM |
Re: Ormerod 1 software upgrade July 24, 2015 12:59PM |
PNut
I constantly get a "heater fault" error when the hot end heats up. The hot end gets to within 5'C then seems to stop heating and so the fault appears after 150 seconds.
There doesn't appear to be any fault in the hot end (I can easily reach temperatures above 230'C)
Re: Ormerod 1 software upgrade July 25, 2015 12:46PM |
Re: Ormerod 1 software upgrade July 26, 2015 04:32PM |
Re: Ormerod 1 software upgrade July 29, 2015 05:51AM |
Re: Ormerod 1 software upgrade July 29, 2015 09:09AM |
GregL
Ormerod 1 #17
I have been getting the occasional heater error message.
Applied your step 3, Ian.
Selected 235 for the heater, and it went up on full power to 234.1 and levelled instantly. Stayed around 234.0 - 234.3.
Set bed to 110, and the heater dropped to 233.5 plus or minus a little bit.
Bed has got to 89 so far - looking good.
Keep your fingers crossed.
Greg
PS now printing ABS and still looking good - head at 220 (+0.2 to -0.7) and bed at 100 (+0.1 to -0.8)
PPS print finished fine. I shall incorporate the fix in my config file
Re: Ormerod 1 software upgrade January 19, 2016 03:44AM |
