Coming back after a year July 28, 2015 04:30AM |
Re: Coming back after a year July 28, 2015 10:15AM |
spiff
So yesterday, I went on and printed the parts for installing the differential Z-sensor. I am fairly pleased with the print quality, although the white homing tab is somewhat uneven, especially near the top layers. Could this be due to the filament not being properly stored? The white filament is the reel that came with my ormerod, and has been in a zipper bag for this past year, but I realize there was no desiccant in the bag.
Re: Coming back after a year July 28, 2015 01:25PM |
Re: Coming back after a year July 28, 2015 02:42PM |
Yes, I am using Slic3r 1.2.9. Do you have additional information about when this bug occurs?Quote
dmould
It could be caused by a known Slic3r bug (if you used that to slice). Loose belts can also cause that banding. Printing slower can cure a lot of symptoms (but not the underlying problem), so maybe print the same file again but use the web interface speed slider to slow to 75% or so.
Re: Coming back after a year July 29, 2015 10:19AM |
spiff
dmould
Re: Coming back after a year July 31, 2015 08:23AM |
dmould
I've not followed it closely, but look here [github.com] and here [forums.reprap.org]
Dave
Re: Coming back after a year July 31, 2015 08:42AM |
Radian
Hey spiff, it sounds like you're doing better than me at getting back up to speed! I'm trying hard to keep up with the developments around here now as it was unexpectedly painful skipping a whole year. Some horrible tenants in a rental property of mine soaked up all my spare time (and then some) last year fixing the near complete destruction of the place.
Re: Coming back after a year August 03, 2015 02:15PM |
spiff
dmould
Dave
Thanks. I suppose, if it is a slicer bug, that it should be possible to find it in the g-code. And I could also try to print the part again, to see if the results are the same.
But I guess I will initially just use the existing part, which I guess will work fine.
Re: Coming back after a year August 11, 2015 08:19AM |
M906 X800 Y1000 Z1000 E800 ; Motor currents (mA)
Re: Coming back after a year August 11, 2015 12:11PM |
Re: Coming back after a year August 11, 2015 02:13PM |
spiff
...I suppose the explanation could be that I have a bit more tension on the X-belt, after installing the new X-arm?..
..Anyway, I noticed that my X-motor current was only 800mA, so perhaps the easiest fix is to turn it up to 1000.
Re: Coming back after a year August 12, 2015 04:02AM |
Darathy
check if the belt is sliping where its attached at the X caridge ,also check if the grub screw is tight on the pully. i have my X motor current set to 800 and it works fine .i think its the belt sliping becouse u probably tightened it a bit more then it was before.
ormerod168
or the belt/pulley not centered or belt not pushed home in the slot on the X-carriage? - if not, "there will be a great rubbing of parts. Yeeah"...(Thunder Prophet, Life of Brian)
ormerod168
..and BTW, the same goes for Y-axis if belt too tight
ormerod168
Yes I have X at 1000 and Y at 1200 (the bed moves a lot of mass) and Z at 800, yours at 1000mA may be overkill but it doesn't matter
M906 X1000 Y1200 Z800 E1200 ; Set motor currents (mA)
Re: Coming back after a year August 12, 2015 07:12AM |
Check if you fully pluged in the cable on the stepper motor.Quote
spiff
Thank you for your suggestions.
Darathy
No, it dosn't seem like the belt is slipping in the X-carriage. Grub screw seems tight (and has not been removed during my X-arm replacement). I never had problems before with 800mA, only after I installed the new X-arm.
An additional note is that I am pretty sure I heard this buzzing noise when the skip occurred, which is why I believe it was stepper motor skips.
ormerod168
Nice pictures
It could be the X end idler that is too tight. I will check that out.
ormerod168
Yes, I had that happen as well.
ormerod168
I cant remember when I upped this, but I am quite sure I hade some problems with skipping steps. But the original Z-axis lead screw and nut got quite worn (I even found metal shavings), so this could easily have been before I replaced the lead screw and put a long brass nut on.
Re: Coming back after a year August 12, 2015 08:25AM |
