Coming back after a year
July 28, 2015 04:30AM
After having my Ormerod in the cupboard for about a year, I stumbled on this thread: [forums.reprap.org]
That inspired me to dig out the machine, and get it printing again.
A year ago I have installed the alu bed support from DD Metal Products, and my heated bed is 3mm aluminium PCB [reprap.me], with a layer of 200mm wide kapton, no glass plate. I also had DC42's differential Z-sensor/hotend board, but I never got around to installing it.
I started with a general cleaning and oiling.
Then updated firmware from 0.57u-dc42 to 1.09c-dc42 (change wiring of one stepper and temp sensor).
And installed ZPL's web interface 1.06.
So yesterday, I went on and printed the parts for installing the differential Z-sensor. I am fairly pleased with the print quality, although the white homing tab is somewhat uneven, especially near the top layers. Could this be due to the filament not being properly stored? The white filament is the reel that came with my ormerod, and has been in a zipper bag for this past year, but I realize there was no desiccant in the bag.
Next will be the installation of the differential Z-sensor.
I have ordered and received an aluminium X-arm kit, which I will be installing after the Z-probe.
Mikkel Holm Olsen
AKA Spaceman Spiff
open | download - P1020333.JPG (62 KB)
open | download - P1020334.JPG (95.3 KB)
open | download - P1020335.JPG (105.9 KB)
open | download - P1020336.JPG (70.7 KB)
open | download - P1020337.JPG (54.4 KB)
open | download - P1020338.JPG (52.3 KB)
Re: Coming back after a year
July 28, 2015 10:15AM
spiff
It could be caused by a known Slic3r bug (if you used that to slice). Loose belts can also cause that banding. Printing slower can cure a lot of symptoms (but not the underlying problem), so maybe print the same file again but use the web interface speed slider to slow to 75% or so.
Dave
July 28, 2015 01:25PM
Hey spiff, it sounds like you're doing better than me at getting back up to speed! I'm trying hard to keep up with the developments around here now as it was unexpectedly painful skipping a whole year. Some horrible tenants in a rental property of mine soaked up all my spare time (and then some) last year fixing the near complete destruction of the place.
RS Components Reprap Ormerod No. 481
July 28, 2015 02:42PM
dmould
Yes, I am using Slic3r 1.2.9. Do you have additional information about when this bug occurs?
Mikkel Holm Olsen
AKA Spaceman Spiff
July 29, 2015 10:19AM
spiff
dmould
I've not followed it closely, but look here [github.com] and here [forums.reprap.org]
Dave
Edited 1 time(s). Last edit at 07/29/2015 10:22AM by dmould.
July 31, 2015 08:23AM
dmould
Dave
Thanks. I suppose, if it is a slicer bug, that it should be possible to find it in the g-code. And I could also try to print the part again, to see if the results are the same.
But I guess I will initially just use the existing part, which I guess will work fine.
Mikkel Holm Olsen
AKA Spaceman Spiff
July 31, 2015 08:42AM
Radian
Thanks. Well, then I hope my posts here can give you a little inspiration to get going. I must say that I feel the printer is working much better than before, most likely due to the firmware and web interface updates.
For me, what soked up my spare time was the birth of my second child.
Mikkel Holm Olsen
AKA Spaceman Spiff
August 03, 2015 02:15PM
spiff
dmould
Dave
IIUC the bug is that the infill between perimeters is over-extruded (pushing the perimeters out), and so it won't be readily visible in the G-code.
Dave
August 11, 2015 08:19AM
Sunday I got the hotend board installed. Looks good and works pretty well, although I am wondering if it would be even more accurate with a different surface. My print bed is 3mm ALU PCB (tracks on the bottom, with a very thin layer of FR4), and a layer of 200mm wide kapton.
Yesterday I managed to fit the aluminium X-arm kit from DD Metal. Looks really good, and quite sturdy.
So the first test print, with this new setup was the Extended Z-nut trap by jstck.
First attempt was going fine, but after about half an hour, I noticed that there had been a skip in the X-direction, so I aborted the print.
Then I did a new attempt, and once again there was a skip in the X direction, but this time smaller, and later in the print. I think this print will work, even with the skip.
I suppose the explanation could be that I have a bit more tension on the X-belt, after installing the new X-arm?
Anyway, I noticed that my X-motor current was only 800mA, so perhaps the easiest fix is to turn it up to 1000.
M906 X800 Y1000 Z1000 E800 ; Motor currents (mA)
Mikkel Holm Olsen
AKA Spaceman Spiff
August 11, 2015 12:11PM
check if the belt is sliping where its attached at the X caridge ,also check if the grub screw is tight on the pully. i have my X motor current set to 800 and it works fine .i think its the belt sliping becouse u probably tightened it a bit more then it was before.
Edited 1 time(s). Last edit at 08/11/2015 12:13PM by Darathy.
August 11, 2015 02:13PM
spiff
...I suppose the explanation could be that I have a bit more tension on the X-belt, after installing the new X-arm?..
or the belt/pulley not centered or belt not pushed home in the slot on the X-carriage? - if not, "there will be a great rubbing of parts. Yeeah"...(Thunder Prophet, Life of Brian)
..and BTW, the same goes for Y-axis if belt too tight
..Anyway, I noticed that my X-motor current was only 800mA, so perhaps the easiest fix is to turn it up to 1000.
Yes I have X at 1000 and Y at 1200 (the bed moves a lot of mass) and Z at 800, yours at 1000mA may be overkill but it doesn't matter
M906 X1000 Y1200 Z800 E1200 ; Set motor currents (mA)
Erik
August 12, 2015 04:02AM
Thank you for your suggestions.
Darathy
No, it dosn't seem like the belt is slipping in the X-carriage. Grub screw seems tight (and has not been removed during my X-arm replacement). I never had problems before with 800mA, only after I installed the new X-arm.
An additional note is that I am pretty sure I heard this buzzing noise when the skip occurred, which is why I believe it was stepper motor skips.
ormerod168
Nice pictures smiling smiley
It could be the X end idler that is too tight. I will check that out.
ormerod168
Yes, I had that happen as well.
ormerod168
I cant remember when I upped this, but I am quite sure I hade some problems with skipping steps. But the original Z-axis lead screw and nut got quite worn (I even found metal shavings), so this could easily have been before I replaced the lead screw and put a long brass nut on.
Mikkel Holm Olsen
AKA Spaceman Spiff
August 12, 2015 07:12AM
spiff
Darathy
ormerod168
ormerod168
ormerod168
Check if you fully pluged in the cable on the stepper motor.
August 12, 2015 08:25AM
The part shown has a significant overhang, and my guess is that it developed a curl-up during printing which caught the nozzle and caused the motor to miss a step.
Dave
