Printing PETG & Motor Voltage August 08, 2015 10:12AM |
Re: Printing PETG & Motor Voltage August 08, 2015 11:25AM |
Re: Printing PETG & Motor Voltage August 08, 2015 01:34PM |
Re: Printing PETG & Motor Voltage August 09, 2015 10:39AM |
Re: Printing PETG & Motor Voltage August 09, 2015 10:53AM |
Re: Printing PETG & Motor Voltage August 10, 2015 07:33AM |
Re: Printing PETG & Motor Voltage August 10, 2015 01:11PM |
dmould
Moisture would not cause the extruder to skip. I think the photo is showing the effect of a skipping extruder rather than moisture - note the shorter infill lines are OK - I am assuming that the extruder starts skipping on longer infill lines (which is very typical).
You can safely increase the current to 1000mA (1A), and then reduce the print speed until the motor no longer skips. Other things that cause skipping are low hotend temperature, too low Z height on first layer, and a partially blocked nozzle. Thicker layers need slower print speeds as there is more plastic being extruded.
Dave
Re: Printing PETG & Motor Voltage August 10, 2015 01:47PM |
Re: Printing PETG & Motor Voltage August 11, 2015 02:41PM |
Re: Printing PETG & Motor Voltage August 12, 2015 07:21PM |
Re: Printing PETG & Motor Voltage September 04, 2015 09:07AM |
Re: Printing PETG & Motor Voltage September 04, 2015 03:39PM |
Re: Printing PETG & Motor Voltage September 05, 2015 02:49AM |
Re: Printing PETG & Motor Voltage September 26, 2015 07:47PM |
