New firmware release 1.09e-dc42 August 10, 2015 03:06PM |
dc42
* Added H (height correction) parameter to G30 command, to allow for the Z probe trigger height varying with XY position
* G30 S-1 now reports trigger height without changing the Z origin
* Changed interrupt priorities to make step pulse timing interrupt higher priority than Ethernet (thanks zombiepantslol)
Re: New firmware release 1.09e-dc42 August 12, 2015 02:47PM |
Re: New firmware release 1.09e-dc42 August 12, 2015 05:45PM |
Re: New firmware release 1.09e-dc42 August 13, 2015 07:39AM |
Re: New firmware release 1.09e-dc42 August 13, 2015 08:14AM |
Re: New firmware release 1.09e-dc42 August 13, 2015 09:42AM |
Re: New firmware release 1.09e-dc42 August 13, 2015 11:00AM |
bitfield
The original ones that came in SDImage folder from your repo.
Re: New firmware release 1.09e-dc42 August 13, 2015 01:34PM |
Re: New firmware release 1.09e-dc42 August 13, 2015 02:19PM |
Re: New firmware release 1.09e-dc42 August 13, 2015 04:11PM |
Re: New firmware release 1.09e-dc42 August 14, 2015 04:11AM |
G10 P1 S185 R0 ; Set extruder temperature T0 ; Select extruder
Re: New firmware release 1.09e-dc42 August 14, 2015 05:20AM |
G28 ; home all axes M83; G10 P0 S195 R160 ; Set tool 0 operating and standby temperatures T0
Re: New firmware release 1.09e-dc42 August 14, 2015 05:30AM |
Warning: Tool 0 was not driven because its heater temperatures was not high enough
Re: New firmware release 1.09e-dc42 August 14, 2015 12:50PM |
Re: New firmware release 1.09e-dc42 August 14, 2015 05:26PM |
G21 ; set units to millimeters M107 M190 S[first_layer_bed_temperature] ; wait for bed temperature to be reached T0 G10 P0 S[first_layer_temperature] R160 ; Set tool 0 operating and standby temperatures M104 S[first_layer_temperature] ; set temperature ; layer_height = [layer_height] M83
Re: New firmware release 1.09e-dc42 August 14, 2015 07:23PM |
Re: New firmware release 1.09e-dc42 August 14, 2015 07:26PM |
dc42
The T0 command needs to go before the M190 command.
Re: New firmware release 1.09e-dc42 August 16, 2015 02:10PM |
Re: New firmware release 1.09e-dc42 August 16, 2015 03:18PM |
21:1710Error: Triangle interpolation: point outside all triangles! 21:17:10Error: Triangle interpolation: point outside all triangles! 21:17:10Error: Triangle interpolation: point outside all triangles!in the g code console. Especially when print is done and head is moving to X0 Y200.
Re: New firmware release 1.09e-dc42 August 16, 2015 03:21PM |
Re: New firmware release 1.09e-dc42 August 16, 2015 03:48PM |
Re: New firmware release 1.09e-dc42 August 18, 2015 05:06PM |
Re: New firmware release 1.09e-dc42 August 19, 2015 04:00AM |
bitfield
I see a lot of
Re: New firmware release 1.09e-dc42 August 19, 2015 05:30AM |
Re: New firmware release 1.09e-dc42 August 19, 2015 07:51AM |
Re: New firmware release 1.09e-dc42 August 19, 2015 10:36AM |
Re: New firmware release 1.09e-dc42 August 24, 2015 10:12AM |
Re: New firmware release 1.09e-dc42 August 24, 2015 11:24AM |
Re: New firmware release 1.09e-dc42 August 24, 2015 11:33AM |
Re: New firmware release 1.09e-dc42 August 24, 2015 12:02PM |
cpbee
Hmmm,
When I erase and reset the board it is ttyACM0
Bossac: Basic Open Source SAM-BA Application (BOSSA) Version 1.3a
After flashing there is NO assignment of device to the Duet: There is only "USB disconnect".
When I flash the regular RepRap firmware the "normal" ttyACM0 device is mounted.
What more infos do you need.
