Hi Brian
Sorry, we've run down our stocks of the old one-piece stainless nozzle, and have no 0.5mm nozzles, and a few 0.3mm nozzles. We don't plan on ordering any more. The latter could be drilled out to 0.5mm, though a lathe would be the best way to do this to avoid broken drill bits.
The 'upgrade' to a Quick set nozzle doesn't offer much practical benefit, apart from easier build (see [
reprappro.com] ) and maintenance. The main benefit is if you have multiple nozzles; firstly, it's easy to mount two in the one cooling block, and secondly it's easy to level them.
To update the old nozzle, use this kit, and reuse the Bowden tube, heatsink, fan, heater cartridge, thermistor and the rest of the wiring: [
reprappro.com]
I hope that helps.
Ian
RepRapPro tech support
