I'm getting pointy ears on the corners of my prints August 15, 2015 08:23AM |
Re: I'm getting pointy ears on the corners of my prints August 15, 2015 09:37AM |
Re: I'm getting pointy ears on the corners of my prints August 15, 2015 12:01PM |
Re: I'm getting pointy ears on the corners of my prints August 15, 2015 12:15PM |
Re: I'm getting pointy ears on the corners of my prints August 15, 2015 12:36PM |
OCLarson13
Thanks Treito,
I'm printing on Kapton Tape. What bed temperature would you recommend?
What can I do if the nozzle is too deep?
I'd appreciate it if you could have a look at the attached photo.
Re: I'm getting pointy ears on the corners of my prints August 15, 2015 12:37PM |
Re: I'm getting pointy ears on the corners of my prints August 16, 2015 01:15PM |
Re: I'm getting pointy ears on the corners of my prints August 16, 2015 01:20PM |
Re: I'm getting pointy ears on the corners of my prints August 16, 2015 01:50PM |
Re: I'm getting pointy ears on the corners of my prints August 16, 2015 10:22PM |
Re: I'm getting pointy ears on the corners of my prints August 17, 2015 03:00AM |
Re: I'm getting pointy ears on the corners of my prints August 19, 2015 04:30PM |
Treito
As a beginner you should not try to print directly on glass. This is very hard and depending on the material it can work or not.
Re: I'm getting pointy ears on the corners of my prints August 20, 2015 02:04AM |
Re: I'm getting pointy ears on the corners of my prints August 20, 2015 03:03AM |
Treito
I have material here that prints on glass (from 3dfilaments.ie and some others) and others not (from other suppliers). I never got ABS to stick on glass and I will not use hairspray or an aceton soup. That is fact. And as I told this is nothing for beginners. Fact is that the material stick on glass not as good as on Kapton or Blue Painters Tape.
As you have to level your bed exactly and set up the height correctly (last one you can probe if in doubt) you should have gain some experience and that is what I said.
Re: I'm getting pointy ears on the corners of my prints August 20, 2015 03:43AM |
Re: I'm getting pointy ears on the corners of my prints August 20, 2015 03:59AM |
Re: I'm getting pointy ears on the corners of my prints August 20, 2015 06:50AM |
dc42
I've give up printing ABS until I have an enclosure for my printer, because I believe the particulates emitted are likely to be a health hazard - they certainly made me cough for a while.
Re: I'm getting pointy ears on the corners of my prints August 23, 2015 08:31AM |
Re: I'm getting pointy ears on the corners of my prints August 23, 2015 02:42PM |
Treito
And I also do not think that the angle of your nozzle is the right one. It seems to be skewed.
