Replacement fan for Ormerod 1 hotend
Posted by pandionx
August 18, 2015 05:27PM
So like an idiot I accidentally stuck the end of my needle nose pliers into the fan of my ormerod while it was running, and the result, predictably, is now a broke vane on the fan.
Since I need to replace it anyway, I figured I might as well upgrade to a PWM fan, but the examples on the forum all refer to 4-wire fans, and the ones I can get locally all have 3 wires.
I can get the following fans locally, would either one of them suffice as a replacement?
http://za.rs-online.com/web/p/axial-fans/0426358/
http://www.3dprintingstore.co.za/electronics/fan-40mm-x-40mm-12v-sunon-maglev-bearing/
Re: Replacement fan for Ormerod 1 hotend
August 19, 2015 04:10AM
If you mean the hot end cooling fan, don't use a PWM fan. That fan should be running whenever the hot end is above about 40C, otherwise you are likely to get a nozzle blockage.
August 19, 2015 04:34AM
Ah! Thanks for the clarification DC.
On a side note, using your IR sensor, I find the fan comes on intermittently even when the hot-end temp is around 21. It seems related to the LED on the sensor coming on. Is this by design, or do I have a short somewhere?
August 19, 2015 07:47AM
pandionx
Could be a short, or possibly a poor connection to the board. Can you induce the fault by waggling the cables attached to the board? It is essential to provide strain relief for the cables, otherwise the constant flexing as the head moves along the X axis will break them at where they enter the crimp pins.
August 25, 2015 05:46PM
It looks like the issue was due to a bad connection I made to the Molex connector. The new fan does not exhibit the problem.
August 25, 2015 05:55PM
DC, just to clarify - you say not to use a PWM fan. The fan speed setting on the firmware/web interface, is that then for additional fans you mount for active cooling?
August 25, 2015 06:21PM
pandionx
That's right, it's for a print cooling fan connected to the FAN0 pins of the Duet. The hot end fan needs to run whenever the hot end is above about 40C. That's why it is normally connected directly to the supply voltage.
