Ormerod 2 z-Probe / X Carriage hanging at printed parts September 23, 2015 03:57PM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 23, 2015 04:41PM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 02:57AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 03:42AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 04:03AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 04:29AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 06:43AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 08:20AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 08:58AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 09:27AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 24, 2015 04:41PM |
cpbee
thanks for your answer. It was the stock RepRap Pro carriage print that was delivered when I bought the Ormerod MII V3 ... ok. I will reprint the part. Then I will look to set the angle correctly. The bed is leveled with a dial gauge. It seems ok, but the problem is the 3 point (instead of 4 points)
No I do not use auto level bed compensation.
I use the MDF spacer.
@dc42: There is a space of 1.5 mm ...
The problem somehow aggrevates when I print multiple larger objects or one larger object where the z-probe area is moving over the object. Can I use another spacer (e.g. 6mm) to "push" the nozzle further down?
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 25, 2015 01:13AM |
Darathy
IF you put a spacer of 6mm it will prob make the Probe too high and will not get accurate readings ,consequently will not be able to home Z.
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 25, 2015 10:32AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 25, 2015 11:01AM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 26, 2015 01:58PM |
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 26, 2015 02:09PM |
cpbee
I do not know which is the correct way but rotating it 180° solved it. BUT I must say, that the Z sensor might be too much away to properly work - I never got the sensor really working. I think only dc42's sensor is the answer.
Re: Ormerod 2 z-Probe / X Carriage hanging at printed parts September 27, 2015 01:49PM |
