Re: Switches for x,y,z November 09, 2015 03:51PM |
Treito
The sensor works indeed better than the original sensor but only partly. It is nearly light independant. Really funny. I put a really bright light source under the sensor and it was still able to detect the height. I only had a difference of 10 digits with light on and off.
Re: Switches for x,y,z November 09, 2015 04:53PM |
Re: Switches for x,y,z November 09, 2015 06:27PM |
Re: Switches for x,y,z November 10, 2015 12:45AM |
Re: Switches for x,y,z November 12, 2015 12:32PM |
dc42
You can use both a Z switch and a proximity sensor if you want, just use M574 to enable or disable the switch. You could also set up macro files to change the Z probe trigger height to handle different bed surfaces. You may find the trigger height varies less if you put black paper under the glass, or paint the aluminium heat spreader black.
M558 P0 Z0; Don't use height sensor for Z-probe, fallback on limit switch M574 Z1 S1 ;Set Endstop type for Z-Axis to End-Stop at 0, active = high G30
M558 P0 Z0 ;Don't use z-probe for Z endstop M574 Z1 S1 ;Set Endstop type for Z-Axis to End-Stop at 0, active = high G1 Z-2000 F200 S1 ; home z
; Configuration file for RepRap Ormerod ; RepRapPro Ltd ; ;M111 S0 ; Debug off M550 POrmerod ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;New version of firmware supports DHCP via 0.0.0.0 M552 P192.168.0.98 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.0.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z1000 E800 ; Set motor currents (mA) M563 P1 D0 H1 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 E426 ; Set extruder steps per mm - 364 is for Black CADHouse PLA ;M92 E424 ; Set extruder steps per mm - 424 is for Funky Blue CADHouse PLA M574 X0 Y2 Z0 S1 ; Y End Stop is at the end - DC Firmware specific M558 P1 ; Use an unmodulated Z probe - DC firmware ;G31 P500 Z2.75 ; Set Z probe height and threshold - DC firmware G31 P500 Z2.60 ; Set Z probe height and threshold - DC firmware M561 ;Cancel any axis compensation M557 P0 X55 Y25 ; Five... M557 P1 X55 Y175 ; ...probe points... M557 P2 X175 Y175 ; ...for bed... M557 P3 X175 Y25 ; ...levelling... M557 P4 X115 Y100 ; ...DC Firmware style - DC recommends using the average of the X and Y's ;M557 P4 X125 Y100 ; ...DC Firmware style M556 S78 X0 Y0 Z0 ; Put your axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute
Re: Switches for x,y,z November 12, 2015 05:07PM |
Re: Switches for x,y,z November 12, 2015 05:46PM |
Re: Switches for x,y,z November 12, 2015 09:15PM |
Re: Switches for x,y,z November 13, 2015 12:33AM |
Re: Switches for x,y,z November 13, 2015 03:33AM |
Re: Switches for x,y,z November 14, 2015 01:01PM |
Treito
I put the paper down under the nozzle and moved it slowly down until I barely could pull out the paper.
I noticed the values, entered it and the skirt looked awful.
Besides that: We live in the 21st century so I demand from my printer to do this automatically.
Besides regarding my Ormerod 1 the bed leveling seems to change for some reasons but I do not exactly why. One possibility could be if you remove a part and it stucks somewhere and a screw is not 100% tight you may get twisted rods.
Besides the additional costs for a MK3 aluminium heated bed to a MK2B or MK2A is less than the cost for the glass if you would like to have a good glass (borosilicate).
Did you ever tried a FLIR?
I do not believe that the heat is spreaded exactly the same high all over the bed you will have hot spots or you need a damn good insulation which overtakes this job.
Re: Switches for x,y,z November 15, 2015 02:34AM |
Re: Switches for x,y,z November 15, 2015 04:18AM |
Re: Switches for x,y,z November 15, 2015 05:08AM |
Re: Switches for x,y,z November 16, 2015 07:17AM |
Treito
... The second problem is that the manufacturing process of this kind of glass does not guarantee that this glass is even. To be 100% sure you need borosilicate glass which starts at 6€ for our printer.
Re: Switches for x,y,z November 16, 2015 09:11AM |
Re: Switches for x,y,z November 17, 2015 07:25AM |
Treito
Unluckily a FSR is a little bit expensive.
Re: Switches for x,y,z November 17, 2015 08:23AM |
Re: Switches for x,y,z November 17, 2015 10:17AM |
16:01:39 G32 Bed equation fits points [50.0, 20.0, -0.162] [50.0, 175.0, 0.089] [195.0, 175.0, -3.196] [195.0, 20.0, -2.336] 16:00:54 G32 Bed equation fits points [50.0, 20.0, -0.683] [50.0, 175.0, 0.074] [195.0, 175.0, -3.161] [195.0, 20.0, -2.277] 16:00:06 G32 Bed equation fits points [50.0, 20.0, -0.607] [50.0, 175.0, 0.074] [195.0, 175.0, -3.144] [195.0, 20.0, -2.297] 15:59:20 G32 Bed equation fits points [50.0, 20.0, -0.188] [50.0, 175.0, 0.072] [195.0, 175.0, -3.065] [195.0, 20.0, -2.295] 15:58:39 G32 Bed equation fits points [50.0, 20.0, 0.016] [50.0, 175.0, 0.134] [195.0, 175.0, -3.023] [195.0, 20.0, -2.255]
Re: Switches for x,y,z November 17, 2015 11:58AM |
Re: Switches for x,y,z November 17, 2015 12:08PM |
Re: Switches for x,y,z November 17, 2015 12:30PM |
Re: Switches for x,y,z November 17, 2015 04:59PM |
Treito
That means the E0 is switched with GND instead of 3.3V like it is common using Atmel microchips?
Re: Switches for x,y,z November 17, 2015 05:47PM |
Re: Switches for x,y,z November 18, 2015 07:15AM |
Treito
Thanks for the answer. I wanted to be sure as I was not aware of it until then. I saw it of course but I did not noticed it. Normally you switch with the positive voltage except for the Atmel processors. But I like the idea. And I also fully support that normally the NC contact is used.
Re: Switches for x,y,z November 18, 2015 09:19AM |
Re: Switches for x,y,z November 18, 2015 12:54PM |
Treito
Hello Dave,
there is one simply reason for doing this for Atmel processors: They have an internal pullup resistor so if you use GND as switch contact you do not need an external pullup or pulldown resistor.
Re: Switches for x,y,z November 18, 2015 01:08PM |
Re: Switches for x,y,z November 22, 2015 06:00PM |
23:42:39 G32 Bed equation fits points [50.0, 40.0, -0.060] [50.0, 185.0, -1.055] [195.0, 185.0, -2.194] [195.0, 40.0, 0.637] 23:41:48 G32 Bed equation fits points [50.0, 40.0, -0.051] [50.0, 185.0, -1.063] [195.0, 185.0, -2.181] [195.0, 40.0, 0.661] 23:40:38 G32 Bed equation fits points [50.0, 40.0, -0.049] [50.0, 185.0, -1.066] [195.0, 185.0, -2.186] [195.0, 40.0, 0.660]
Re: Switches for x,y,z November 23, 2015 04:35PM |
