Re: Switches for x,y,z October 03, 2015 11:50AM |
Re: Switches for x,y,z October 05, 2015 10:46AM |
Re: Switches for x,y,z October 06, 2015 07:23AM |
Re: Switches for x,y,z October 06, 2015 11:44AM |
Re: Switches for x,y,z October 06, 2015 01:06PM |
Re: Switches for x,y,z October 06, 2015 01:21PM |
Re: Switches for x,y,z October 06, 2015 02:20PM |
Re: Switches for x,y,z October 07, 2015 06:44AM |
Re: Switches for x,y,z October 07, 2015 10:52AM |
Re: Switches for x,y,z October 08, 2015 01:15AM |
Re: Switches for x,y,z October 08, 2015 04:00AM |
Re: Switches for x,y,z October 08, 2015 06:50AM |
Re: Switches for x,y,z October 08, 2015 07:24AM |
Treito
Maybe I could use a rotating mechanism. As long as the nozzle is up and the bearing on the arm the MS switch is operated but as soon as the nozzle hits the bed and the bearing looses contact the switch is not operated anymore. As the spring of the switch tries to push the rod away from the arm it even may give better accuracy.
Re: Switches for x,y,z October 08, 2015 10:25AM |
Re: Switches for x,y,z October 08, 2015 12:52PM |
Treito
I also had this idea before but it would only make sense if there is a conductive connection between bold and bearing but a slightly contact loss would trigger the switch. I think this would not be practicable.
I have two new ideas. Maybe you could use the proximity switch which is mounted upside down and triggered by the horizontally part of the x-arm or an self-made light triggered switch which is interrupted by the horizontally part of the x-arm.
Re: Switches for x,y,z October 08, 2015 01:13PM |
Re: Switches for x,y,z October 08, 2015 02:35PM |
Re: Switches for x,y,z October 08, 2015 02:41PM |
Re: Switches for x,y,z October 09, 2015 02:27PM |
Treito
No you did not get me right. I would use the tilt effect. As long as the nozzle is over the bed the sensor is looking to the ceiling slightly passing the x-arm. As soon as the sensor hits the bed and the nozzle tilts the sensor is going under the horizontally part of the arm. The light will be reflected and the setting is done. You would need the 4-pin-sensor.
Re: Switches for x,y,z October 09, 2015 05:08PM |
Re: Switches for x,y,z October 10, 2015 06:35PM |
Re: Switches for x,y,z October 11, 2015 05:41AM |
Re: Switches for x,y,z October 11, 2015 07:23AM |
Re: Switches for x,y,z October 12, 2015 06:57AM |
Re: Switches for x,y,z October 12, 2015 11:46AM |
Re: Switches for x,y,z October 12, 2015 12:32PM |
Re: Switches for x,y,z October 12, 2015 02:25PM |
dc42
I spent some time trying to design a modified X runner bearing mount to incorporate a force sensitive resistor, but I didn't produce a design I was happy with.
Re: Switches for x,y,z October 12, 2015 02:57PM |
Re: Switches for x,y,z October 12, 2015 03:22PM |
Re: Switches for x,y,z October 12, 2015 04:36PM |
