Re: Switches for x,y,z October 12, 2015 05:06PM |
Re: Switches for x,y,z October 12, 2015 06:32PM |
Re: Switches for x,y,z October 12, 2015 06:48PM |
Re: Switches for x,y,z October 12, 2015 07:02PM |
Re: Switches for x,y,z October 13, 2015 01:24AM |
Re: Switches for x,y,z October 13, 2015 03:43AM |
Treito
I am afraid that SMD would cause more trouble in placement. Reducing the beam means that you have to arrange the parts more precisely.
Please take a look at the data sheet of my IR-Komponents again especially the IR-transistor. Ignore the technical data and only take a look at the housing:
[www.pollin.de]
The type of the housing allows you to place it directly to the PCB and if your holes are small enough problem number 1 should be solved. The lens is much smaller and especially the coloring of the IR-transistor should reduce problem 2.
Re: Switches for x,y,z October 13, 2015 06:38AM |
Re: Switches for x,y,z October 13, 2015 08:04AM |
Re: Switches for x,y,z October 17, 2015 06:00AM |
Re: Switches for x,y,z October 21, 2015 03:46AM |
Re: Switches for x,y,z October 21, 2015 07:30AM |
Treito
I have a new idea. What about the z-axis-nut? I use for example the extended nut trap version and also a nut with a length of 15 mm. So as soon as the nozzle hit the bed the nut is moving down the nut trap. So if you place a MS at the top or at the bottom of the nut the MS would be triggered as soon as the nozzle hits the bed. Maybe 2 mm later. But I think this would be more accurate than the tilt method.
As soon as I got ressources (my MK2 is not working at the moment, too) I will test the tilt method with my MK2 and the nut method with my MK1. Additionally I will add a modified version of dc42s mini sensor board to my MK1 so I can directly compare both.
Re: Switches for x,y,z October 21, 2015 07:38AM |
Re: Switches for x,y,z October 21, 2015 02:13PM |
dmould
Treito
I doubt it would be accurate. The nut does not move in the Z trap as soon as the nozzle hits the bed - initially the X-arm continues to move down while the hotend tilts. Only after the hotend has reached the limit of its tilt and all the slop in the X-arm attachment has been taken up will the nut move in the trap. I doubt that will be at a height that is consistent to within the 0.1mm (minimum) accuracy required, or indeed as accurate as the tilt movement (which is mechanically amplified by the lever action), but maybe do some tests.
Dave
Re: Switches for x,y,z October 22, 2015 10:08AM |
Re: Switches for x,y,z October 22, 2015 03:19PM |
Re: Switches for x,y,z October 23, 2015 07:13AM |
Treito
Thanks Dave,
unfortunately I am dependant of the proximity sensor for the moment. If there is no space for a bearing - how should this x-carriage work? Or did I get something wrong? Sorry, I had a really bad day.
Re: Switches for x,y,z October 23, 2015 09:15AM |
Re: Switches for x,y,z October 30, 2015 04:15AM |
Re: Switches for x,y,z November 08, 2015 03:54AM |
Re: Switches for x,y,z November 08, 2015 08:53AM |
Re: Switches for x,y,z November 08, 2015 10:09AM |
Re: Switches for x,y,z November 08, 2015 11:03AM |
Treito
At least the best method seems to be the servo motor method. Using this would beat all other methods...
Re: Switches for x,y,z November 08, 2015 11:12AM |
Re: Switches for x,y,z November 08, 2015 12:10PM |
Treito
..In one month I will try to create a full printer which costs less than 250€ and using your sensor I would not have any chance to succeed except I reduce the print quality and this is not my goal...
Re: Switches for x,y,z November 08, 2015 12:28PM |
ormerod168
dirt cheap printer
Re: Switches for x,y,z November 08, 2015 01:43PM |
Treito
ormerod168
dirt cheap printer
Mind your language.
Honestly I want to create a cheap but precise printer. Maybe it exceeds 250€ we will see. Besides I know many people here at the forum including especially me who did not have any success using the paper method. For me it is definitely not working and I prefer to use the proximity switch for manually leveling and some small adjustments afterwards.
..One trick is to use a MK3 heated bed as you are not needing an aluminium spreader but you have the same comfort. maybe you even do not need a print surface and can print directly on the bed as the aluminium version is totally even. That is one trick to safe money...
Re: Switches for x,y,z November 08, 2015 02:33PM |
So you have reached the gramatically end of your translator but nearly correct. You did find the German umlaut?Quote
ormerod168
fingerspitz gefühl :-)
ormerod168
..lets call it a printer on a shoe string budget then :-)
ormerod168
..but why use a aluminium spreaderl?, its not needed, I put mine to better use long ago [forums.reprap.org]
Re: Switches for x,y,z November 08, 2015 09:46PM |
Re: Switches for x,y,z November 09, 2015 12:51AM |
Re: Switches for x,y,z November 09, 2015 02:52AM |
