Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 08:49AM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 01:40PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 04:00PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 04:20PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 05:10PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 05:14PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" September 30, 2015 05:16PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" October 03, 2015 07:58AM |
Ian - RepRapPro tech support
Sorry for the slow reply. We've been getting ready for, and attending (on Wednesday and Thursday) the TCT 3D printing show at Birmingham NEC, which has put us a little behind answering emails.
I think you've posted on the forum, too? Here: forums.reprap.org/read.php?340,564553
And I've also seen your later email, where you said you carried on, and everything seems okay! It took me a little while to work out what you were saying, and where you were reading a resistance. I think you're right; what you were actually reading was the resistance through the PSU (more likely than the 5V regulator board), rather than a fault with the bed and shield. I expect if you had removed one of the wires from the 12V input screw terminals, you would have read no resistance (or, maybe, some capacitive resistance, tending towards infinite resistance). But you took the plunge anyway, and it worked out okay! We tend not to bother putting the bed shield on; it tends to just get in the way, and it's rather difficult to fit without shorting out the contacts..
Re: Ormerod 2 continuity test on the "Heated bed shield" October 05, 2015 10:42AM |
cheeseandham
It does look like I have a fault with the Duet board anyway though, as the Ethernet network connection isn't lighting up when connected! I'm not looking forward to having dismantle all of this
Re: Ormerod 2 continuity test on the "Heated bed shield" October 12, 2015 01:38PM |
Re: Ormerod 2 continuity test on the "Heated bed shield" January 20, 2016 07:33AM |
Re: Ormerod 2 continuity test on the "Heated bed shield" January 21, 2016 04:35AM |
cheeseandham on October 03, 2015 04:58AM
Due to the lack of reply from here and RepRapPro support,.and the fact I thought it was simply passing throught the PSU via the 5V regulator. I took the plunge anyway and carried on commissioning.
It worked.
