upload with bossac in cmd
Posted by florianZac
October 20, 2015 07:13AM
I have a problem with upgrade firmware (the command M105 don't work) and i have a red led rating usb conector
the device its not found
thanks for your help
open | download - Sans titre.png (53.8 KB)
Re: upload with bossac in cmd
October 20, 2015 07:18AM
its very strange because the exe found the com 4 ...
open | download - aa.png (16.9 KB)
October 20, 2015 07:29AM
Did you press the "erase" button on the Duet?
You can use the attached files in any folder. Just drag & drop the firmware BIN file onto the item "reprog.cmd" If the Duet is not on COM4 edit the file "reprog.cmd"
Dave
open | download - tools.rar (241.4 KB)
October 20, 2015 07:46AM
florianZac
In Windows, open Device Manager, expand Ports (COM and LPT) and look for "Bossa port". That will tell you which COM port number to use in the bossac command.
Sorry, I missed your earlier post - you already did that. Press the Reset button on the Duet and try again.
Edited 2 time(s). Last edit at 10/20/2015 07:53AM by dc42.
October 20, 2015 08:19AM
your script don't work .....
(I'm engineer student in IT and electronics device ...)
Here is my script to modify so that photo of the inconsistent result....
@echo off
title RepRapPro Ormerod Flash Utility
echo Please press the 'ERASE' button,
echo then the 'RESET' button and wait
echo at least 10 seconds then:
echo.
pause
echo.
cd C:\Program Files (x86)\Arduino\hardware\tools
dir bossac.exe -U true
pause
echo.
listComPorts
pause
echo.
bossac.exe --port=Com4 -U true -e -w -v -b %1 -R
bossac.exe -e -w -v -b --port=Com4 RepRapFirmware-1.09.bin
echo.
pause
Then I'm ask myself the question: the power suply psu a problem put you it, the jumper in JP9 is it in good place, would need it not better than I create a connector JTAG and what I program him directly there jtag as I always made him on UC.
open | download - aaa.png (26.5 KB)
October 20, 2015 09:08AM
I found a solution .... made it's necessary to remain to rest on reset and erase during sends create higher in this page and its him of the code and his work thank you that straight from for the help
Cordially Florian Aizac
October 20, 2015 11:51AM
florianZac
That's because you tried to run it from the command window. It is designed for drag & drop.
Select firmware file. Hold left mouse button. Drag firmware file to "reprog.cmd" file icon. Release mouse button.
Dave
