More display options for PanelDue October 23, 2015 05:17AM |
Re: More display options for PanelDue October 23, 2015 10:53AM |
dc42
I have found two more displays that should be compatible with PanelDue:
* 4.3 inch and 5 inch screens supplied from Germany, [0wAAOSwBLlVN1Dk" target="_blank" rel="nofollow">www.ebay.co.uk] and [www.ebay.co.uk]. These look the same as the low-cost touch screens from China that I link to in the instructions.
* 7 inch screen from China, [www.ebay.co.uk]. I have one of these on order. It could be ideal for larger printers. It will need a wire link added to the PanelDue controller board to supply 5V to the backlight pin.
I am working on a new version of the PanelDue firmware that will support up to 6 heads on a 5 or 7 inch screen, and 3 or possibly 4 heads on the 4.3 inch screen.
Re: More display options for PanelDue October 23, 2015 11:10AM |
Re: More display options for PanelDue October 23, 2015 11:37AM |
dc42
Doug, It wouldn't be hard to modify the openscad file to support the low cost 5 inch display, but I don't have one to measure, so I can't plug the figures in. If you like I can knock up a version for that display, but you would need to adjust some of the figures.
Re: More display options for PanelDue October 23, 2015 12:58PM |
Re: More display options for PanelDue October 23, 2015 01:46PM |
dc42
That helps, although it doesn't tell me where the visible part of the screen is. I have made a guess and made the changes anyway. Do you want it with or without a lip for hanging off a 2020 or 2040 etc. horizontal extrusion?
Re: More display options for PanelDue October 23, 2015 02:00PM |
Re: More display options for PanelDue October 23, 2015 03:10PM |
dc42
I've checked in a modified version of the .scad file (the version with lip) at [github.com] and added a ready-made STL for your display. Almost certainly, it won't be quite right yet. Let me know what changes are needed.
Re: More display options for PanelDue October 26, 2015 05:46PM |
Re: More display options for PanelDue October 26, 2015 05:58PM |
Re: More display options for PanelDue October 26, 2015 09:20PM |
Re: More display options for PanelDue October 26, 2015 09:28PM |
Re: More display options for PanelDue October 27, 2015 03:27AM |
Re: More display options for PanelDue October 27, 2015 04:22AM |
coogrrr
Speaking of which..... Got a link for the 7" and 5" panel you bought? I will buy the same! Thanks in advance yet again!
James
Re: More display options for PanelDue October 27, 2015 06:03AM |
dc42
coogrrr
James
See the first post in this thread for the link to the 7 inch display - which I haven't received yet, so is not tested. The eBay UK listing for the 5 inch display that I link to on the fitting instructions page has ended, however this one [www.ebay.co.uk] looks compatible to me.
Re: More display options for PanelDue October 27, 2015 12:50PM |
Re: More display options for PanelDue October 28, 2015 01:50PM |
DaveQuote
dougal1957
That is looking good Dave
The Panel and sensor arrived Sat morning by the way and I now have one of those 7 inch screens on order as well.
Should be able to get a case for the 5 out today work permitting.
Doug
Re: More display options for PanelDue October 28, 2015 05:28PM |
LCDview = (Itead43) ? [3,103,7,64.8] : (Itead50) ? [2.5,114.5,3,71.5] : (Other43) ? [3,103,7,64.8] : [2.5,117,3,76]; // The edges of the visible region of the LCD screen (L,R,B,T)
Re: More display options for PanelDue November 03, 2015 03:22PM |
Re: More display options for PanelDue November 03, 2015 06:20PM |
Re: More display options for PanelDue November 03, 2015 06:31PM |
zombiepantslol
Those pins are available on the expansion header, just have a look at this document: [github.com]
Re: More display options for PanelDue November 04, 2015 02:44AM |
Re: More display options for PanelDue November 04, 2015 02:13PM |
dc42
The DueX4 has a 26-pin expansion connector. Connect the PanelDue to that. In the fitting instructions at [miscsolutions.wordpress.com] you will find the pin numbers in the table column "DueX4 expansion connector". I think the pin names are marked on the back of the DueX4. You can use the 8-way shell to connect pins 1, 4 and 5, and the crimp pin by itself to connect pin 21. I am sorry I don't have a photo - I guess I ought to dismantle my Ormerod electronics so that I can take one.
Re: More display options for PanelDue November 04, 2015 02:49PM |
coogrrr
dc42
NOOO!!!!!! please do not disassemble anything on my account - that info was enough for me - I am using +5 and GND from the main PS so I only needed the TX and RX pins - got those now! and to take your lead and try to emulate a master..... I am going to take a picture of mine so others can see too! I have already pulled the 2 crimp pins from the 8-way shell - I added a little heat-shrink around the exposed part leaving only the the open end and now I can slide them onto the Expansion board's 26pin header set at pins 4 and 5 as the post you gave me shows!
Thanks a ton Dave!
James
Re: More display options for PanelDue November 11, 2015 05:26AM |
Re: More display options for PanelDue November 11, 2015 07:07AM |
dougal1957
Dave
My 7 inch screen has just arrived. Have you got yours yet and have you written up the required alteration to the PanelDUE controller board (I am thinking that it will be a link from the 5V in and the LED-A pin on the header but would like it confirming).
dougal1957
Am I right in saying that it would use the same firmware as the 5 inch screen.
dougal1957
Do you plan on amending the enclosure to suite as well?
Re: More display options for PanelDue November 11, 2015 10:22AM |
dc42
dougal1957
Dave
My 7 inch screen has just arrived. Have you got yours yet and have you written up the required alteration to the PanelDUE controller board (I am thinking that it will be a link from the 5V in and the LED-A pin on the header but would like it confirming).Quote
dc42
No. On the 7 inch display there is a pin marked 5V. What is needed is a wire between the corresponding pin on the 40-pin socket, and the bottom pin of the 3.3V/5V jumper block. I will post a photo when my 7 inch display arrives and I have tested this arrangement.
Ah I see that now no Probs!.
dougal1957
Am I right in saying that it would use the same firmware as the 5 inch screen.Quote
dc42
Yes, for now at least.
OK.
dougal1957
Do you plan on amending the enclosure to suite as well?Quote
dc42
Yes.
Excellent
Re: More display options for PanelDue November 13, 2015 08:52AM |
Re: More display options for PanelDue November 13, 2015 09:22AM |
Re: More display options for PanelDue November 13, 2015 11:22AM |
dc42
zpl, thanks for confirming that display works. You might like to try the 1.12 beta 2 firmware if you haven't already.
I am still waiting for my 7" display to arrive. The estimated delivery date was Mon, 09 Nov - Wed, 25 Nov so hopefully it shouldn't be too much longer.
