Re: More display options for PanelDue November 13, 2015 12:42PM |
Re: More display options for PanelDue November 13, 2015 01:05PM |
Re: More display options for PanelDue November 14, 2015 04:54PM |
dougal1957
Dave
Those colours are about right I think when I went into the setup and inverted it it was very strange the calibration was of ie the first spot I had to touch at the oposit side of the screnn the second was where it should be the third I couldn't get at all and the only way out was to reset the board.
There is definitely something different about these 7 inch display's and think it will have to wait till you get your's can't believe that mine arrived first even though I ordered it a few days after you did?
Doug
If need be I'll send it down to you to have a play with if your's doesn't arrive in the next couple of days or so?
Re: More display options for PanelDue November 15, 2015 02:59AM |
coogrrr
Doug,
Did you order using the link Dave provided? I did and mine hasn't shown up yet either. I did order mine after you did but I worry with it taking this long. I guess I will give it a full 30 days to get here?!??! Then go after the seller.
James
dougal1957
Dave
Doug
Re: More display options for PanelDue November 15, 2015 08:00AM |
Re: More display options for PanelDue November 15, 2015 09:06AM |
Treito
I may have one stupid question: Is it possible to get the PanelDue controller PCB alone without display? I only found a bundle at T3P3.
Re: More display options for PanelDue November 15, 2015 09:28AM |
Re: More display options for PanelDue November 15, 2015 03:47PM |
Re: More display options for PanelDue November 15, 2015 04:07PM |
Re: More display options for PanelDue November 15, 2015 04:11PM |
dc42
Currently, if you want to change the colours then you would have to recompile the firmware. It's easy to do if you are running Windows. I may add an option to select your own colours eventually, but not until I have finished providing functionality.
Re: More display options for PanelDue November 15, 2015 04:19PM |
Treito
dc42
Which version of Atmel studio is needed? I would like to upgrade to Version 7, but I have not used it yet as I did my programming with Linux and avrdude so far.
Re: More display options for PanelDue November 16, 2015 02:43AM |
Treito
..I know the differences betwween the screen sizes too well as my old smartphone was eqipped with a 4.5" display and my actual one is equipped with an 5". This is indeed much better, but I am wondering how good you can control the Ormerod by touch. Maybe 5" is a little bit too small for this.
Re: More display options for PanelDue November 16, 2015 04:08AM |
Re: More display options for PanelDue November 16, 2015 05:07AM |
Re: More display options for PanelDue November 16, 2015 05:44AM |
Treito
Hello Erik,
have you any specifications of the displays you used?
Re: More display options for PanelDue November 16, 2015 06:09AM |
Re: More display options for PanelDue November 16, 2015 06:21AM |
Treito
Good example David as this supplier does not ship to Germany.
Treito
I was asking because I also would like to take a look at Aliexpress for example. If I know a type that works I can look more focused.
I guess this won't work until I disassemble it:
[de.aliexpress.com]
same here:
[de.aliexpress.com]
But the connectors are shown. So it seems I only would have to remove the EMC shield?
Re: More display options for PanelDue November 16, 2015 06:33AM |
Re: More display options for PanelDue November 16, 2015 06:53AM |
Re: More display options for PanelDue November 17, 2015 11:02AM |
Re: More display options for PanelDue November 17, 2015 12:00PM |
Re: More display options for PanelDue November 17, 2015 04:39PM |
Re: More display options for PanelDue November 17, 2015 05:24PM |
Re: More display options for PanelDue November 17, 2015 05:57PM |
Re: More display options for PanelDue November 17, 2015 06:00PM |
chrishamm
Thanks David, I've just flashed the 4.3'' version on my PanelDue - nice to see more icons! But could you check if the touch events work on the Control and Print pages of your 7'' display? It seems my PanelDue picks up touch events only randomly on the Console and Setup pages, in fact now I cannot even type a simple command using the display. No idea why, but this was definitely working with b2.
Re: More display options for PanelDue November 17, 2015 06:43PM |
Re: More display options for PanelDue November 17, 2015 06:57PM |
Re: More display options for PanelDue November 18, 2015 04:01AM |
dc42
chrishamm
The 4.3" and 5" displays are working perfectly with 1.12b3 for me. It's only the 7" display that has problems registering touch. I've just checked the datasheet of the touch IC and found a possible explanation.
Re: More display options for PanelDue November 18, 2015 04:27AM |
Re: More display options for PanelDue November 18, 2015 04:46AM |
