Hot end heater - Ormerod 2 November 15, 2015 02:49PM |
Re: Hot end heater - Ormerod 2 November 15, 2015 06:09PM |
Re: Hot end heater - Ormerod 2 November 16, 2015 03:54AM |
Re: Hot end heater - Ormerod 2 November 16, 2015 06:39AM |
Re: Hot end heater - Ormerod 2 November 16, 2015 07:24AM |
Re: Hot end heater - Ormerod 2 November 16, 2015 12:34PM |
Treito
You only have to get Replikeo on the nerves. That means if they do not react you should repeat your e-mails. But I had also trouble with them two times as they do not provide the right paperwork for the customs for example. Getting my replacement Duet was also not an easy task but it worked after roughly 5-10 e-mails.
From where did you order your replacement ehater cartidge? Be warned that not all will filt. If Replikeo uses the original nozzles you may have to use a 5mm heater cartridge. I am not sure what kind of heater cartridge is used at the quick nozzle set.
Re: Hot end heater - Ormerod 2 November 16, 2015 12:44PM |
Re: Hot end heater - Ormerod 2 November 17, 2015 05:11PM |
Re: Hot end heater - Ormerod 2 November 17, 2015 05:59PM |
Re: Hot end heater - Ormerod 2 November 17, 2015 06:21PM |
Re: Hot end heater - Ormerod 2 November 18, 2015 06:37AM |
