New PanelDue firmware released November 25, 2015 05:37PM |
Re: New PanelDue firmware released November 27, 2015 01:36PM |
Re: New PanelDue firmware released November 29, 2015 04:22AM |
Re: New PanelDue firmware released November 29, 2015 06:33AM |
ormerod168
chrishamm
One more suggestion: Could you remove the asterisk from the directory buttons in one of your next releases?
Why would you want that?
Erik
Re: New PanelDue firmware released December 06, 2015 06:00PM |
Re: New PanelDue firmware released December 07, 2015 03:52AM |
Re: New PanelDue firmware released December 13, 2015 03:26AM |
Re: New PanelDue firmware released December 13, 2015 03:55AM |
Treito
One small thing that I do not like very much. If I pause and cancel a print the heaters will be turned off. I would prefer if they would keep on. It is strange as I tested the PanelDue with FW 1.09n-ch and using Firefox the heaters stay on. Why there is a difference between Duet-FW and PanelDue-FW? At least this is really confusing.
I would suggest that both type of firmware will run a macro and this decide if the heaters will stay on or will be turned off. So there would be no dependence on the firmware used.
BTW I was not able to calibrate the Touchpanel at first startup so I had to flash the firmware
Re: New PanelDue firmware released December 13, 2015 04:26AM |
dc42
What I think is needed is a separate "Abandon print" gcode, that in RepRapFirmware would run a macro. In the absence of such a gcode, PanelDue sends M0, which I thought is also what the web interface sends.
Re: New PanelDue firmware released December 13, 2015 04:57AM |
Re: New PanelDue firmware released December 13, 2015 05:14AM |
Re: New PanelDue firmware released December 13, 2015 05:42AM |
Re: New PanelDue firmware released December 13, 2015 06:04AM |
That would be really nice. Many thanks. Otherwise if you do not do this you can assure that the users are doing a firmware upgrade. Seriously this could be indeed an advantage like I said before. BTW I have to rethink my macros. I am using your macros (delivered with your 1.09k-firmware) and accidentally tipped on "Load filament" instead of "Retract 5mm". My extruder motor was not amused very much. My fingers are a little bit too big.Quote
dc42
Regarding the touch panel orientation, in future I'll do a Factory Reset after testing the board, so that it will start up at the touch calibration screen.
Re: New PanelDue firmware released December 13, 2015 08:34AM |
Re: New PanelDue firmware released December 13, 2015 09:27AM |
Re: New PanelDue firmware released December 13, 2015 09:42AM |
Re: New PanelDue firmware released December 14, 2015 08:01AM |
Treito
Is there no heat dissipation needed? I was not asking because of the current which can be delivered. I was asking because of a missing heat sink. I know it will produce less heat due to the switching regulator design, but no heat? I will have to check the datasheet once I found out which type is used. But now I am on a new problem. Thread is coming soon.
Re: New PanelDue firmware released December 14, 2015 06:39PM |
Re: New PanelDue firmware released December 15, 2015 03:55AM |
