Y axis microswitch EMI issue December 04, 2015 04:39AM |
Re: Y axis microswitch EMI issue December 04, 2015 05:02AM |
Re: Y axis microswitch EMI issue December 04, 2015 06:19AM |
Re: Y axis microswitch EMI issue December 04, 2015 07:10AM |
Re: Y axis microswitch EMI issue December 04, 2015 01:51PM |
Re: Y axis microswitch EMI issue December 04, 2015 01:59PM |
Re: Y axis microswitch EMI issue December 04, 2015 03:30PM |
Re: Y axis microswitch EMI issue December 05, 2015 02:23AM |
Re: Y axis microswitch EMI issue December 05, 2015 05:39AM |
Darathy
Only Problem that annoys me with Ormerod 2's microswitch is the position of it. It gets disconected a lot of times becouse the connectors dont hold on to the pins anaugh and soldering would complicate disasembeling the printer.
Re: Y axis microswitch EMI issue December 06, 2015 04:51AM |
dc42
The push-on connectors don't fit the microswitch tags properly and tend to fall off. I soldered some standard 0.1" header pins to the microswitch tags, insulated the soldered bits with heatshrink, and slipped the push-on connectors on them. That was over a year ago, and they have not fallen off since then.
Re: Y axis microswitch EMI issue December 06, 2015 06:37AM |
Darathy
dc42
you mean this:[www.pololu.com] to the switch?
Re: Y axis microswitch EMI issue December 07, 2015 06:54AM |
Darathy
Re: Y axis microswitch EMI issue December 07, 2015 11:45AM |
Re: Y axis microswitch EMI issue December 07, 2015 03:56PM |
Re: Y axis microswitch EMI issue December 08, 2015 06:52AM |
Treito
Regarding the Ormerod 2 only a short distance is needed. So I directly soldered mine to the switch (not the original one). In my eyes is does not make any sense to use an additional connector at this short distance. But how do you avoid that the wires of the cables could get in touch with the rotary parts that means with the pulley?
Re: Y axis microswitch EMI issue December 08, 2015 11:21PM |
