Re: Duet failure? January 09, 2016 09:36AM |
Re: Duet failure? January 09, 2016 09:39AM |
Re: Duet failure? January 09, 2016 03:26PM |
Re: Duet failure? January 09, 2016 04:35PM |
Re: Duet failure? January 09, 2016 05:32PM |
; Ormerod 2 config file for dc42 Duet firmware M111 S0 ; Debug off M550 PMy Ormerod ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P192.168.178.114 ; IP address M554 P192.168.178.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M574 X0 Y1 Z0 S1 ; set endstop configuration (Y endstop only, at low end, active high) M906 X1000 Y1000 Z800 E900 ; Set motor currents (mA) M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures M92 E420 ; Set extruder steps per mm (single nozzle) ;*** If you have a dual-nozzle build, remove or comment out the previous line, and un-comment the following 3 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ;M92 E420:420 ; Set extruder steps/mm (dual nozzle) ;*** If you have a modulated IR probe with on-board microcontroller, change P2 to P1 in the following M558 P1 ; Use a simple modulated Z probe (change to P1 for an intelligent Z probe) G31 Z2.7 P500 ; Set the probe height and threshold (put your own values here) ;*** If you have a Duet board with 4.7K thermistor series resistors, change R1000 to R4700 to the following M305 commands M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the IR sensor M557 P0 X50 Y25 ; Four... M557 P1 X50 Y195 ; ...probe points... M557 P2 X200 Y195 ; ...for bed... M557 P3 X200 Y25 ; ...levelling M557 P4 X120 Y104 ; 5th probe point for levelling (un-comment this if you are using a dc42 differential IR probe) ;*** if you are using axis compensation, put the figures in the following command M556 S74 X0.0 Y0.3 Z0.5 ; Axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X1800 Y1800 Z30 E20 ; Minimum speeds mm/minute M208 X200 Y210 ; set axis maxima (adjust to suit your machine) M208 X-1 Y0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed) M92 X87.49 Y87.49 M301 H1 P20 I0.5 D100
Re: Duet failure? January 09, 2016 05:35PM |
Darathy
How do i open the console?
Re: Duet failure? January 09, 2016 05:51PM |
M92 X87.49 Y87.49 M301 H1 P20 I0.5 D100to
;M92 X87.49 Y87.49 ;M301 H1 P20 I0.5 D100
M92 X78.740 Y78.740 E420 ; Set extruder steps per mm (single nozzle) and x/y steps per mm
Re: Duet failure? January 09, 2016 06:46PM |
Re: Duet failure? January 09, 2016 06:51PM |
GET [192.168.178.114] GET [192.168.178.114] GET [192.168.178.114] 500 (too few command words) GET [192.168.178.114] 500 (too few command words) GET [192.168.178.114] 500 (too few command words)
Re: Duet failure? January 09, 2016 06:57PM |
Re: Duet failure? January 09, 2016 11:32PM |
Re: Duet failure? January 10, 2016 05:06AM |
Re: Duet failure? January 10, 2016 05:09AM |
Darathy
...it annoys me that i have to powercycle(or reset) it several times to be able to connect to the webinterface at all.
Re: Duet failure? January 10, 2016 07:06AM |
Re: Duet failure? January 11, 2016 07:30AM |
Re: Duet failure? January 11, 2016 07:39AM |
Re: Duet failure? January 11, 2016 08:27AM |
Treito
Dave,
the problems about the cache were already confirmed by ZPL/ chrishamm.
Re: Duet failure? January 11, 2016 08:49AM |
Re: Duet failure? January 11, 2016 09:34AM |
Treito
...So A button to clear or delete the cookie would be a nice addition for the web-interface.
Re: Duet failure? January 11, 2016 12:23PM |
dmould
Intermittent hardware problems are usually due to bad solder connections. Check that all the pins on the Ethernet connector are properly soldered - there were manufacturing issues at one time where some of the through-hole components (and also the USB connector) did not get all their pins soldered.
Dave
Re: Duet failure? January 11, 2016 12:29PM |
Darathy
dmould
Dave
I have posted a picture of the pins in post above ,to me they look soldered well(underneath the duet atlaeast) is there above section to worry abaut too?
I have visualy checked the board and nothing seems amis to me.
Re: Duet failure? January 11, 2016 12:43PM |
Re: Duet failure? January 12, 2016 01:04AM |
Re: Duet failure? January 12, 2016 04:02AM |
Re: Duet failure? January 12, 2016 04:07AM |
Re: Duet failure? January 12, 2016 04:23AM |
dc42
Unfortunately there appears to be a bug in the latest version of Firefox because it refuses to upload large files on my system. A Wireshark trace showed the Duet doing nothing untoward that I could see. I found out how to clear cookies in Chrome for just the Duet session, but I can't remember the details.
Re: Duet failure? January 12, 2016 04:26AM |
Re: Duet failure? January 16, 2016 05:51AM |
Re: Duet failure? January 16, 2016 08:33AM |
chrishamm
It would be interesting to hear if these problems persist once you upgrade to DWC v1.08 and my latest firmware version. If it does and you're using Windows, please perform a TCP/IP stack reset. If that doesn't cure your symptoms, please send me a Wireshark dump so I can look into this again.
Re: Duet failure? January 16, 2016 09:08AM |
