Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 01:45PM |
Anonymous User
Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 07:44PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 08:15PM |
1pennyshort
Are you in US? I've had pretty good luck with Hatchbox PLA filaments from Amazon.
I have yet to print in ABS, so can't really compare.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 16, 2015 10:41PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 17, 2015 08:38AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 17, 2015 01:25PM |
brlowe
I found that once I started looking, was going to order from hobby king but even from US warehouse shipping was high, I get free 2 day shipping from amazon so going to try that first.
With the Ormerod 2 is there a problem using ABS and melting something in the pro t head or the holder?
How do you fix this if it is an issue?
Re: Looking to buy 3D printer and looking at Ormerod 2 December 17, 2015 02:39PM |
Documentation
Advice
Important: all the supplied printer parts are made from PLA. Long term exposure to the heat of ABS printing will cause some of them to fail. If you plan to print a lot of ABS, you should first reprint some of the parts from ABS, specifically (and in this order) the x-carriage, z-runner-mount, extruder-body and the rest of the extruder parts, nozzle-duct, fan-duct.
When printing ABS without upgraded parts, at the start of the print leave the x-axis high above the bed (at least 100mm) so that it is not getting hot while the bed heats up.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 18, 2015 04:44AM |
brlowe
@VortyZA
"I use my I3 primarily for ABS, Nylon and Polycarbonate printing because I have an all metal hot end - the Ormerod can do ABS (with some very essential part reprinting), but not the higher temperature stuff."
What needs to be done to the ormerod 2 to let you print with the higher temp stuff? and what does that mean? And what parts need to be reprinted before doing ABS?
Thank you everyone
I live in South Africa, so I'm not sure my source will be much good for you!Quote
0x0000
@VortyZA, where do you source your polycarbonate filament from?
I've seen it offered on a few websites in UK and US however.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 19, 2015 11:27PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 02:31AM |
Anonymous User
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 09:40AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 04:06PM |
Giantkiller
@omerod168,
I have no usable gears and am looking for herringbone set. I would like the small gear to have the grub hub collar. Any advice? Can you print a set and sell to me?
I have seen sets for sale but don't trust the axle diameter specification.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 05:52PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 06:02PM |
I would definately like your omerods and with Herringbones? The grub hub collar makes the installation on the motor hub much simpler. If no collar then thats ok.Quote
ormerod168
Giantkiller
@omerod168,
Can easily print a set for you for free, no problem - but I have not seen any model with grub hub collar, why would you want that?
My guess is that you have foreseen the problem with the interlocking gear, that both gears that have to be mounted at the same time so you want the small gear to slip unto the axle with no resistance and arrest it with the grub screw when in place
Yes, to install those gear wheels on the stock extruder gives me the creeps!
[attachment 68094 HeeringBoneGearsExtruder.JPG]
This problem do not exist with MasonStoneHenge's springloaded extruder that I highly recommend
RepRap Pro Ormerod Spring-loaded extruder
[www.thingiverse.com]
How about this: I am about to change color on my 2. born Ormerod1, I could send you the ABS printed spring loaded extruder pars with wheels, suitable spring included, and in Christmas Green no less!
..or if you find a model of the small gear with grub hub collar I could print that instead if you prefer that
Erik
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 06:48PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 06:52PM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 20, 2015 08:36PM |
Treito
Sorry, but can anybody answer a person who's first language is not English and who is no mechanical engineer one stupid question? What the hell is a grub hub collar?
Re: Looking to buy 3D printer and looking at Ormerod 2 December 21, 2015 02:23AM |
Giantkiller
I had the dual hot end replikeo and need to get able to print so I can move on into other parts. How shall we go about this?
Re: Looking to buy 3D printer and looking at Ormerod 2 December 21, 2015 04:44AM |
Treito
Re: Looking to buy 3D printer and looking at Ormerod 2 December 21, 2015 04:57AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 21, 2015 09:04AM |
Treito
Hello Doug. I know a grub screw very well. This is called "Madenschraube" in German. But a "grub hub collar" was too much. Why not simply grub screw? Or is there a difference? I cannot look at the video for the moment.
Re: Looking to buy 3D printer and looking at Ormerod 2 December 21, 2015 11:38AM |
Re: Looking to buy 3D printer and looking at Ormerod 2 December 22, 2015 11:54AM |
