Re: Ormerod 1 prints does not look good. December 19, 2015 11:24AM |
Darathy
ormerod168
this would do nicely, glue it to the x-arm with a very thin layer of Loctite 648:
Erik
Would epoxy glue work aswell? like thisone:[www.hobbyking.com]
I have some at home and wondering if it would hold it. Would Loctite 648 hold it better?
Re: Ormerod 1 prints does not look good. December 19, 2015 11:41AM |
Re: Ormerod 1 prints does not look good. December 19, 2015 12:47PM |
Re: Ormerod 1 prints does not look good. December 19, 2015 12:58PM |
ormerod168
Darathy
ormerod168
Erik
Not much info there so I do not know if it will hold against a steel surface
The glue should be:
Able to adhere to aluminium and steel
Thin (so any variation in the layer of glue will be small, the shim should follow the straight surface of the x-arm)
Slow drying (as to give time for the shim to even out the glue layer to the x-arm)
From the Loctite 648 product description:
"The product cures when confined in the absence of air between close fitting metal surfaces"
Any excessive glue wont dry and can be wiped of
..but if I were you I would just go ahead and try what you have, no harm done if it don't stick, rough up the surface a bit, apply a thin even layer and use a lots of clamps (clothespins will do fine)
Erik
Re: Ormerod 1 prints does not look good. December 19, 2015 01:54PM |
Darathy
i see your point, this glue is verry dense and would probably make the surface uneaven.
Re: Ormerod 1 prints does not look good. December 20, 2015 04:43AM |
Re: Ormerod 1 prints does not look good. December 20, 2015 12:49PM |
Re: Ormerod 1 prints does not look good. December 20, 2015 12:57PM |
Re: Ormerod 1 prints does not look good. December 20, 2015 01:45PM |
Re: Ormerod 1 prints does not look good. December 20, 2015 01:56PM |
Re: Ormerod 1 prints does not look good. December 23, 2015 07:01AM |
chrishamm
dmould
I decided to get my X-arm anodized - mainly for the appearance (it's a really nice electric blue colour). But anodizing also creates a harder surface on the aluminium, and perhaps that it why there is no sign of wear under the bearing despite having had a lot of use. Anodizing a single part is however likely to cost as much as the arm!
Dave
Sounds interesting, now I'm curious what that looks like :-) Could you post a photo?
Re: Ormerod 1 prints does not look good. December 23, 2015 11:46AM |
Re: Ormerod 1 prints does not look good. December 23, 2015 12:07PM |
Re: Ormerod 1 prints does not look good. December 23, 2015 02:57PM |
dmould
Treito
Looks nice but you have also a trace of the bearing. Is there a groove?
I'll have a close look when I get back, but AFAIK that's just dust that has been deposited by the bearing.
Dave
Re: Ormerod 1 prints does not look good. December 24, 2015 01:29AM |
Darathy
dmould
Treito
Dave
Thats how mine looked it was in the begining stages had like a tiny groove starting to form. Otherwise that blue arm looks really awsome!
Re: Ormerod 1 prints does not look good. December 24, 2015 10:36AM |
Re: Ormerod 1 prints does not look good. December 24, 2015 08:44PM |
Re: Ormerod 1 prints does not look good. December 31, 2015 04:04AM |
Re: Ormerod 1 prints does not look good. December 31, 2015 04:53AM |
Re: Ormerod 1 prints does not look good. December 31, 2015 06:03AM |
I was lucky to get the last 300mm lineal.|
Re: Ormerod 1 prints does not look good. December 31, 2015 10:58AM |
It was too fast so I was not able to correct it anymore. Do you know how long I have to wait until I can reassemble my printer?|
Re: Ormerod 1 prints does not look good. January 03, 2016 01:11PM |
I really hope this fits. I have to get back my MK1 back to work as two parts of my MK2 nearly broke (construction issue) and another 2 or three parts needs to be replaced (printing issue, now I know the cause). Besides that I would like to exchange the pulleys of my MK2 so they have also 18 teeth.|
Re: Ormerod 1 prints does not look good. January 06, 2016 05:53PM |
Re: Ormerod 1 prints does not look good. January 16, 2016 03:04PM |
Re: Ormerod 1 prints does not look good. January 16, 2016 05:54PM |
Treito
So I am nearly finished, but I only could use the original MR93ZZ bearing as the bigger one caused that the nozzle was not angled.
I have a new problem with this d*** printer. Now the heater cartridge slipped off the heater block. Maybe I really should consider replacing the nozzle with a chinese 0.4mm nozzle.
Meanwhile my Ormerod 2 urgently needs a service. For example the bed support is melted. The ABL can fix this problem at the moment, but who knows how long?
Re: Ormerod 1 prints does not look good. January 16, 2016 06:23PM |
Recommissioning didn't succeed, because the sensor was too deep so I didn't get the first layer to stick and if there would have been a chance the sensor would remove the print. So I need a new spacer.
