2×3 female black crimp socket
Posted by Europa
December 13, 2015 12:38PM
Gents,
Where in the UK or even in Europe can I buy a replacement 2×3 female black crimp socket as fitted to the Ormerod 2 first version?
I have looked everywhere without any success, I am sure the problem is that it is not commercially called a "2×3 female black crimp socket" which is why I cannot find one.
Thank you,
Brian
Re: 2×3 female black crimp socket
December 13, 2015 01:24PM
Europa
Gents,
Thank you,
Brian
something like 2x3 housing do
Doug
December 13, 2015 01:33PM
Thanks Doug,
It might possibly work but as I am only replacing the female half of the plug and socket I really need to get the same type.
I am fitting an all metal hot end which comes without a plug, if I can just change the hot end plug I can then keep the half on the wiring loom.
Brian
December 13, 2015 01:49PM
If you mean the 6-pin hot end connector, then possibly Molex 43025-0600 mating with 43020-0600, or TE Connectivity 794615-6, plus associated crimp pins. All available from Farnell. Best ask RepRapPro for the part numbers to be sure.
December 13, 2015 01:53PM
Europa
Thanks Doug,
Brian
OK they are commonly called a DUPONT Conector and I am sure you can fine plenty of them try this search
2x3 dupont shells
Doug
to be honest anything with a 2.54 mm pitch on the pins will do for you.
December 13, 2015 01:59PM
Thanks guys,
I will see what I can find, at least I know what they are called now.
Brian
December 13, 2015 02:32PM
So what kind of connector are you talking of? The hot-end area or the Duet area, but I would guess the hot-end area. So dc42 gives you the right identification. I prefer the TE connectivity (as I was not able to get the Molex parts here). It seems they are slightly more stable than the Molex parts. I tested both of them and you can fully interchange them, but I do recommend a crimping tool. BTW you do not want to know the price for the original crimping tool of TE. grinning smiley
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
