Web & Panel suggestion December 15, 2015 08:13AM |
Re: Web & Panel suggestion December 15, 2015 08:25AM |
Re: Web & Panel suggestion December 17, 2015 09:07AM |
dmould
1) How many people need all 3 time estimates? (Filament, layer, file). Personally I only ever bother with the estimate based on filament use. If that's not available for any reason the next best IMO is layer time, and finally file usage is usually the least accurate IME. The three estimates take up quite a bit of space on the page and yet two will likely never be looked at. My suggestion is to show only the (usually) most accurate estimate available, or allow the user to dynamically select which to show (maybe via radio buttons) rather than always showing all 3 estimates.
dmould
2) I also miss having the "last layer time" that disappeared in the latest web interface. Some prints have a section that will require a bit of "babying", and if you know how many layers to go before it reaches that place and the approximate current layer time, you can estimate when it will reach that point so as to be on hand at the printer. Sure, I can look at the graph and do the conversion from seconds, but having it displayed in figures is easier. That useful parameter was replaced with a static display of the warm-up time throughout the print - something that I cannot see is likely to be of much interest after the print has started. I think most of us already know how long the warm-up takes for each material we print.
Re: Web & Panel suggestion December 17, 2015 11:01AM |
chrishamm
mandrav, this works in DWC v1.07 - I checked this yesterday when I printed a few parts. But I believe DWC doesn't automatically switch over to the print page when a new print is started from PanelDue, so I'll look into this once again.
Re: Web & Panel suggestion December 17, 2015 12:08PM |
I understand - my suggestion was to have 3 radio buttons so the user can select which estimate to bring up.Quote
chrishamm
It's no news that the filament-based estimation is the most accurate one, but if it is unavailable (e.g. because a G-code file was uploaded by Pronterface), the other two estimations should provide at least a rough estimation. I will leave the file-based estimation in there because both RRP's dev and my firmware fork can interface Roland mills, and the G-code for such mills doesn't provide file information that could be used for the other estimations.
Thanks - that would be great.Quote
chrishamm
Yes - I see the point. I'll change the behaviour of the web interface in my next version, so the warm-up time is only displayed while the machine is heating up. This way I can free up one cell and put the last layer time in there once again. FYI, when a layer finishes, the last layer time will stay in the "Layer time" cell for two seconds and a CSS3 fade effect is shown, but I realise you don't want to keep an eye on it all the time.
Re: Web & Panel suggestion December 17, 2015 02:35PM |
mandrav
chrishamm
Uhm, I 'm using 1.07 already... Maybe I did something stupid? Will double check.
No PanelDue here. The interface switches to the printing page automatically when starting a new print.
Thanks for your hard work Chris
An AJAX error was reported, so the current session has been terminated. Please check if your printer is still on and try to connect again. Error reason: SyntaxError: JSON.parse: unexpected character at line 1 column 530 of the JSON data
Error! The following JSON response could not be parsed: interface.js:993:4 {"status":"P","coords":{"axesHomed":[0,0,0],"extr":[2470.3],"xyz":[-4.12,7.11,59.55]},"currentTool":0,"params":{"atxPower":1,"fanPercent":0.00,"speedFactor":100.00,"extrFactors":[100.00]},"seq":4,"sensors":{"probeValue":1000,"fanRPM":0},"temps":{"heads":{"current":[199.0],"active":[0.0],"standby":[0.0],"state":[2]}},"time":1729.3,"currentLayer":196,"currentLayerTime":0.9,"extrRaw":[2470.3],"fractionPrinted":99.4,"firstLayerDuration":1.3,"firstLayerHeight":0.35,"printDuration":1319.3,"warmUpDuration":1.1,"timesLeft":{"file":inf,"filament":0.0,"layer":0.0}} interface.js:994:4
Firmware Name: RepRapFirmware Firmware Version: 1.09m-dc42 (2015-12-08) Web Interface Version: HTML: 1.07, JS: 1.07
Re: Web & Panel suggestion December 17, 2015 05:02PM |
