PanelDue is not starting
Posted by Treito
December 20, 2015 01:28AM
Hello,
I am using the PanelDue with firmware 1.13. My Ormerod 2 uses the firmware 1.09n-ch. After starting or restarting the Ormerod the PanelDue only shows the status "starting up" and that is it. What am I doing wrong?
Funnily the homing for example does work, but I am getting no feedback.
Best regards,
Sven
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
Re: PanelDue is not starting
December 20, 2015 02:39AM
Sounds like the PanelDue is sending data to the Duet but not getting any back. Two suggestions:
1. Check the connection from the Din pin on the PanelDue to the TxD pin on the Duet.
2. Try with my 1.09m-dc42 firmware on the Duet.
Edited 1 time(s). Last edit at 12/20/2015 02:49AM by dc42.
December 20, 2015 02:44AM
Many thanks for the answer. I will check the first one first. That sounds to me the most likely reason as I am having really trouble with the connectors since I use the case.
What I Forgot to mention: After restarting the PanelDue everything is fine.
December 20, 2015 05:04PM
Treito
I confirm that this is caused by an issue with the code in 1.09n-ch. it does not occur in any of my firmware releases. I have emailed chrishamm advising him of what he needs to change.
December 20, 2015 06:20PM
*Oops* Okay many thanks for testing. I gave the ch-firmware a shot as I had trouble with your k-version because of stability especially regarding the network. As you both use some different network stack I tried ch's FW. But I recently thought of giving your -m-version another try as I have really trouble uploading files. The size of files often differs after uploading or the files get corrupted when I abort a print. Okay maybe the card needs to be reformatted, but it is more likely that the problem is a firmware related.
My currently (again) broken Ormerod 1 still uses your problematic FW version. First I wanted to update this printer to test your m-version. I will report about the stability. I think it will take me something about 20 hours to be able to flash your FW.
December 20, 2015 07:00PM
I expect to release 1.09o-dc42 tomorrow, and in that version I use chrishamm's latest network stack.
December 20, 2015 07:04PM
dc42
That would be perfect so I would wait until this release. I really hope that my file issues are not related to the network stack.
