New Fillament printing issues December 27, 2015 06:05PM |
Re: New Fillament printing issues December 28, 2015 05:09AM |
tig124
If you look at the following link,
[techyman3d.blogspot.co.uk]
The Black print is using new fillament from Fillamentum It has a recommended print temperature of 190 - 220, as I have explained I have been setting this to 190, however it looks like it has been too hot (if you look at the top of the print it has some sagging ) as opposed to the white print which is straight... Have I got this prognosis right? Is it possible that the temperature needs to go lower even though this would be below the minimum of the , or is something else going on here?
Thanks
Re: New Fillament printing issues December 28, 2015 09:33AM |
Re: New Fillament printing issues December 28, 2015 01:19PM |
tig124
No I don't have a cooling fan, i will try printing out two of them though... However the white PLA printed fine
Re: New Fillament printing issues December 28, 2015 01:57PM |
Re: New Fillament printing issues January 04, 2016 03:45PM |
Darathy
tig124
Thanks
Do you have a cooling fan? if not try printing 2 or three of them at some distance from each other to give them time to cool ,it is a very small part and would require quite a lot of cooling.
Re: New Fillament printing issues January 08, 2016 06:37PM |
