New Fillament printing issues
Posted by tig124
December 27, 2015 06:05PM
If you look at the following link,
[techyman3d.blogspot.co.uk]
The Black print is using new fillament from Fillamentum It has a recommended print temperature of 190 - 220, as I have explained I have been setting this to 190, however it looks like it has been too hot (if you look at the top of the print it has some sagging ) as opposed to the white print which is straight... Have I got this prognosis right? Is it possible that the temperature needs to go lower even though this would be below the minimum of the , or is something else going on here?
Thanks
Re: New Fillament printing issues
December 28, 2015 05:09AM
tig124
Thanks
Do you have a cooling fan? if not try printing 2 or three of them at some distance from eachother to give them time to cool ,it is a verry small part and would require quite a lot of cooling.
Edited 1 time(s). Last edit at 12/28/2015 05:11AM by Darathy.
December 28, 2015 09:33AM
No I don't have a cooling fan, i will try printing out two of them though... However the white PLA printed fine
December 28, 2015 01:19PM
tig124
Yes ,might be due to Dye that the company uses ,diferent colors might require diferent temperatures and companys. You can try lowering temperature aswell ofc.
Edited 1 time(s). Last edit at 12/28/2015 01:19PM by Darathy.
December 28, 2015 01:57PM
..and a darker filament will absorb more radiated heat from the nozzle
Erik
January 04, 2016 03:45PM
Darathy
tig124
Thanks
Do you have a cooling fan? if not try printing 2 or three of them at some distance from each other to give them time to cool ,it is a very small part and would require quite a lot of cooling.
I would recommend using a cooling fan when printing with PLA.
I been printing parts using a luminous green filament from the same manufacturer. At first the print speed was slow 35 mm/s and the external perimeters where curling up, causing failed prints. From some research I found that running the printer faster at 45mm /s and external perimeters speed was auto (0) or 50% in slic3r settings. Hot end was set to temp setting of 195 degrees C this gave better prints. Had the cooling fan set to default settings in slic3r
January 08, 2016 06:37PM
Excellant interesting , I will check these against the fillament setting I have.. Gives me a good start.
