I've come across the following issue:
ormerod2 running v1.0.9 firmware won't print anything.
reflashed firmware 3 times & commissioned from scratch, nothing.
X, Y & Z homes, I can extrude and I can manually position bed
Always hangs on following:
starts to load print, does bed equation then hangs.
(I know set up isn't 100% yet, but even with perfectly level bed it did the same)
bed equation fits points [45.0,0.0,-0.011] [45.0,180.0,-0.219] [210.0,0.0,-0.486]
Loaded files via usb, web and sd card, no luck.
Any ideas?
