E3D V6 nozzle with Ormerod 2. January 03, 2016 06:57AM |
Re: E3D V6 nozzle with Ormerod 2. January 03, 2016 07:14AM |
Europa
Hello, I have purchased a generic E3D V6 and are about to fit to my Ormerod 2.
My nozzle seems to be good quality and it is a perfect fit to the mount I have printed from thingyverse.
Would someone please let me know in simple English which changes I need to make to my config file, the new hotend is fitted with a 100K glass bead thermistor. (my original setup has a 4K7 thermistor)
The nozzle is 0.4mm which I will change in the slicer profile from 0.5mm.
Many thanks for any help.
Brian
dc42
I've just done some investigation, and it looks to me that although E3D say you should use a B value of 4267 in RepRapFirmware for the thermistor they supply, a value of 4388 will give more accurate temperature readings. I will shortly start a new thread on thermistor B values.
Re: E3D V6 nozzle with Ormerod 2. January 03, 2016 12:48PM |
M305 P1 R4700 H0 L0 B3950 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
Re: E3D V6 nozzle with Ormerod 2. January 04, 2016 06:13AM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 03:41AM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 06:54AM |
M305 P1 B3950The H and L parameter are for calibration purposes only and not needed. That is why I used "0". I only prepared those entries.
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 07:11AM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 12:34PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 01:32PM |
Change it toQuote
Europa
Hi Treito,
My current config file with the original hotend has the following M305 entry.
M305 P1 R4700
Do I change the above to:
M305 P1 100000 B3950
There are no H or L setting in the original line, not sure what they are for?
Many thanks,
Brian
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 01:55PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 02:38PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 02:39PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 03:15PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 03:43PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 03:55PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 03:59PM |
Re: E3D V6 nozzle with Ormerod 2. January 05, 2016 04:04PM |
Re: E3D V6 nozzle with Ormerod 2. February 12, 2016 06:43AM |
Re: E3D V6 nozzle with Ormerod 2. February 12, 2016 01:18PM |
Re: E3D V6 nozzle with Ormerod 2. February 12, 2016 01:41PM |
Re: E3D V6 nozzle with Ormerod 2. February 26, 2016 04:07PM |
Re: E3D V6 nozzle with Ormerod 2. February 26, 2016 04:10PM |
Re: E3D V6 nozzle with Ormerod 2. February 26, 2016 04:12PM |
Re: E3D V6 nozzle with Ormerod 2. February 26, 2016 04:21PM |
Re: E3D V6 nozzle with Ormerod 2. February 26, 2016 05:02PM |
Re: E3D V6 nozzle with Ormerod 2. February 27, 2016 07:05AM |
Re: E3D V6 nozzle with Ormerod 2. February 27, 2016 08:40AM |
derek5a
BUT It mentions that the command doesn't work with any firmware?
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: E3D V6 nozzle with Ormerod 2. February 27, 2016 12:41PM |
Traumflug
derek5a
Perhaps, because it's an entirely pointless command. Temperature is controlled all the time, so before temperature gets even close, heaters are already turned off.
It needs quite some imagination to construct a case where such a temperature is reached and the firmware manages to avoid damage. If the firmware works, it doesn't get there and if the firmware doesn't work, it's unlikely it can heal its self. Instead of writing such code it's better to make sure the existing code is reliable.
Re: E3D V6 nozzle with Ormerod 2. February 29, 2016 07:40AM |
Traumflug
derek5a
Re: E3D V6 nozzle with Ormerod 2. February 29, 2016 07:46AM |
derek5a
Ultimately for the application of the RepRap I need to extend this temperature value as we are planning on using the system to dual extrude Polycarbonate and Polyetherimide.
