Re: RepRapPro closing down January 08, 2016 11:52PM |
0x0000
The MDF spacer is part #641, according to the CSV parts list. The DXF itself can be found here: [github.com]
If you're using an E3D hotend, you don't need it.
Re: RepRapPro closing down January 09, 2016 12:45AM |
Re: RepRapPro closing down January 09, 2016 01:19AM |
Treito
Hi all,
but what about the Exruder? Don't forget this one. The hobbed insert is hard to get and when you get it the price is high. Somebody should recreate another one, based on common tiles, preferably the MK8 gear for example. And it is not because I got some here
I choosed them as it seems that these are the best choice for transporting filament.
Best regards,
Sven
Re: RepRapPro closing down January 09, 2016 01:56AM |
Re: RepRapPro closing down January 09, 2016 02:24AM |
Re: RepRapPro closing down January 09, 2016 03:29AM |
Re: RepRapPro closing down January 09, 2016 04:49AM |
0x0000
I had to order mine from RRP's extruder kit. There are instructions for making a hobbed bolt on the RepRap wiki, which I would have attempted if I had the tools to do so. Obviously not as good as a commercially machined part, and I felt that the relatively low cost was worth the expense. It was definitely cheaper than all of the tools
Re: RepRapPro closing down January 09, 2016 07:38AM |
Re: RepRapPro closing down January 09, 2016 12:50PM |
Re: RepRapPro closing down January 09, 2016 02:05PM |
Re: RepRapPro closing down January 09, 2016 07:56PM |
droftarts
Sorry about this, everyone, and thanks for all your support over the years.
I was made redundant on 11th December. I've stayed away from the forums since then to avoid any embarrassing questions, until there was an official announcement. I'll help out where I can, though I don't actually own an Omerod! I do have a Fisher, though, and might be able to have the Tall-merod at some point.
Anyone want to employ a technical support engineer?! Any (helpful) suggestions gratefully received!
Ian
ex-RepRapPro tech support
Re: RepRapPro closing down January 09, 2016 11:43PM |
dc42
Think3DPrint3D uses the same hobbed insert on their Mini Kossel extruder I believe, so I expect the hobbed insert will continue to be available from them.
Re: RepRapPro closing down January 10, 2016 12:14AM |
Treito
T3P3 unfortunately is very expensive. This may be caused because it is a small company, but 6 GBP for a hobbed insert? I earlier paid only about 60% of this price probably less for one. And there are only a few shops whose have this in stock and some of them are even more expensive. That is why I am considering to use standard components. In my eyes it would be indeed a better way to use standard components as the Ormerod is spreaded world wide and not every country can get such kind of parts. Think about those persons. This is much more important than the price. (I even would pay such a high price for a hobbed insert as it is only one time for a dual nozzle upgrade which costs much more so this little costs are not much noticeable).
Re: RepRapPro closing down January 10, 2016 12:19AM |
Re: RepRapPro closing down January 10, 2016 12:43AM |
Treito
You could use other controllers like RAMPS with the Ormerod. Why you have not seen any report? Nobody would do that because you only will have disadvantages. It is harder to setup, a web-interface is not easy to get and they are as well problematic like the Duet.
I am unsure if I will buy a Duet 0.85 for my new printer design. It will be of Dual nozzle support. I have a spare Duet 0.6 here and also a Duet shield, but this was mainly intended for my Ormerod 2.
Re: RepRapPro closing down January 10, 2016 01:43AM |
Re: RepRapPro closing down January 10, 2016 03:29AM |
Treito
dc42
@cheeseandham: I do not think that there would be a problem to reserve a page where you can get parts. These pages already exists at the wiki for the heated beds or for the common hobbed inserts for example.
Re: RepRapPro closing down January 10, 2016 03:33AM |
0x0000
I've got my finger on the order button for a Duet 0.8.5 on T3P3, but I'm going to have a think about it before placing my order. I do like the Duet and think it's well worth the money, but I've seen so many complaints about its reliability (including my own failed board.
Re: RepRapPro closing down January 10, 2016 03:34AM |
Re: RepRapPro closing down January 10, 2016 03:37AM |
dc42
I am intrigued by the suggestion that some of these might be caused by a faulty SD card, and I have been in touch with T3P3 regarding how to protect the microcontroller from that.
Re: RepRapPro closing down January 10, 2016 03:44AM |
Re: RepRapPro closing down January 10, 2016 03:49AM |
Re: RepRapPro closing down January 10, 2016 04:10AM |
Treito
Two questions:
Was that the reason why one Duet board of mine was broken? Or even both? Even though the SD-card was working well at my PC? Meanwhile I luckily exchanged the card with a faster one, but it would be important to know for me. Couldn't you use the internal temperature sensor for monitoring the MCU temperature to shut it down?
Treito
Edit: Sorry I can only count to two and not to four.
Re: RepRapPro closing down January 10, 2016 04:18AM |
Re: RepRapPro closing down January 10, 2016 05:13AM |
Re: RepRapPro closing down January 10, 2016 06:18AM |
Treito
Hi all,
but what about the Extruder? Don't forget this one. The hobbed insert is hard to get and when you get it the price is high. Somebody should recreate another one, based on common tiles, preferably the MK8 gear for example. And it is not because I got some here
I choose them as it seems that these are the best choice for transporting filament.
Best regards,
Sven
Re: RepRapPro closing down January 11, 2016 02:21AM |
Re: RepRapPro closing down January 11, 2016 08:31AM |
Re: RepRapPro closing down January 11, 2016 08:55AM |
Re: RepRapPro closing down January 11, 2016 09:33AM |
droftarts
Hi everyone
I should also point out that, while I was one of the few 'public-facing' members of the RRP team, there were more of us, and I feel equally badly that they lost their jobs at the same time as me; Joe (who worked for RRP for even longer than me, in production, mainly packing kits), Tom (production, made all the wiring looms and packed kits) and Chris (junior mechanical engineer/designer). There are also the three directors; Sally (who many of you know through sales/admin), Jean-Marc (managing director and head mechanical engineer) and Adrian (engineering R&D, and figurehead!). While Adrian is comfortable in his retirement, the other two still need to put food on the table! We also had a round of lay-offs earlier in the year - Claire (production manager), Joe '90' (ran the production of printed parts), Brad (production), Mark (who did a bit of everything) and, latterly, Nathan (production). I miss working with all these unique people, for the imagination, shared vision and just the general banter and fun we had, and wanted to list them so everyone appreciates the full team that was behind RRP.
Ian
