Re: RepRapPro closing down January 08, 2016 03:45AM |
Re: RepRapPro closing down January 08, 2016 07:06AM |
Davek0974
No reason it would need to be 316, any stainless is pretty nasty to machine.
I have no equipment small enough to drill a 0.5 or 0.3mm hole though.
Re: RepRapPro closing down January 08, 2016 07:09AM |
Re: RepRapPro closing down January 08, 2016 08:12AM |
dmould
Davek0974
I should think that a pillar drill would be capable of doing the job (using a PCB drill bit e.g. [www.pcbsupplies.co.uk]), though a higher speed drill such as a Dremmel would be better.
Dave
Re: RepRapPro closing down January 08, 2016 08:25AM |
Mitch
For Christmas a relative of mine got an Ormerod 2 from Replikeo. It has the Quick-set hotend. The hotend parts looked great. The only thing that seemed a bit battered/dogy was the metal clamping block that holds the nozzles to the printer. Nonetheless it functioned fine. The original ormerod 2's from Replikeo used the standard nozzles but they have since changed to the quick-set hotends.
Re: RepRapPro closing down January 08, 2016 08:27AM |
Davek0974
dmould
Davek0974
Dave
To get that size hole, you will need to be spinning the drill at 110,000 rpm or 10m/min tip speed, feed rate would be around 0.01mm/rev, not a drillpress job )
Dremel will get maybe 10,000rpm.
You need an air spindle.
Re: RepRapPro closing down January 08, 2016 08:34AM |
Anonymous User
Re: RepRapPro closing down January 08, 2016 09:01AM |
Mitch
Re: RepRapPro closing down January 08, 2016 09:34AM |
orictosh
Also the tolerances on that hole are 0.30mm +- 0.02mm
Hand holding a Dremel might at best give +- 0.50mm So worse case nozzle size is 0.80mm rather than the 0.30mm needed/ordered by customer.
I would think also using a worn out drill bit would push it out of tolerances as well.
Re: RepRapPro closing down January 08, 2016 09:35AM |
Re: RepRapPro closing down January 08, 2016 09:40AM |
shadow651
Has anyone ever tried this multicolor filament merger that Adrian posted to the O2 GitHub a couple of years ago? [github.com]
Re: RepRapPro closing down January 08, 2016 10:03AM |
shadow651
At this point I'm thinking this might be an easier solution for multi-color upgrades. You would only need to get a DueX4 (depending on your duet version), bowden tubing, and the bowden brass unions.
The only real question would be where to get more brass union pieces?
Re: RepRapPro closing down January 08, 2016 10:07AM |
Re: RepRapPro closing down January 08, 2016 10:30AM |
dmould
orictosh
Why do you say the tolerance is so tight? Considering that you can print with any nozzle size between about 0.3mm and 1.0mm, I don't see why the tolerance needs be particularly good - the nozzle size does not determine the extrusion width, only its minimum and maximum width and max speed. If the nozzle is not quite the same size as has been set in the slicer it will not affect the print significantly (though you could always set the size retrospectively to be equal to whatever the diameter of the hole turns out to be - as measured by inserting various SWG wires).
You can buy a small hobbyist drill press that takes a Dremmel, or probably fabricate something to hold the tool for a one-off hole.
Dave
Re: RepRapPro closing down January 08, 2016 10:52AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: RepRapPro closing down January 08, 2016 11:49AM |
DADIY
shadow651
They have some photos on twitter showing a dual version of this working printing a frog on the Fisher printer, however how do you configure a slicer to know what to do?
Also dhgate have the bowden start/end - dont know if they are any good as Ive never delt with them.
[www.dhgate.com]|221821102
G1 E100 F3600 ; move filament most of the way down the multicolor connector G1 E5 F100 ; move down the rest of the way
G1 E-5 F100 G1 E-100 F3600
Re: RepRapPro closing down January 08, 2016 11:59AM |
A good designer on the other hand will not specify a tolerance tighter than what is required.Quote
orictosh
The tolerances are stated on the Drawing of the 0.30mm quick-set-nozzle inside file 737.pdf
A good engineer will do his best to obtain that value, some of the engineers I have approached have stated they can't obtain that level with their current equipement and would need investment to obtain equipment that would be able to produce that value.
Filament diameter has nothing whatsoever to do with nozzle diameter. The filament diameter affects the volume of plastic that is extruded, which is completely independent of the nozzle diameter. You could print the exact same G-code file through nozzles with diameters of 0.4mm, 0.5mm and 0.6mm and there will be practically no difference in the prints produced.Quote
orictosh
You say nozzle size does not determine extrusion width, I strongly disagree. If the filament diameter is larger or smaller than entered in slic3r that causes over/under extrusion resulting in a failed/bad quality of the printed design.
Re: RepRapPro closing down January 08, 2016 12:25PM |
As said above, there's only one correct flow rate for bridging: the one that doesn't make your bridge sag or break.
Extrusions are round and their diameter is equal to the nozzle diameter.
Re: RepRapPro closing down January 08, 2016 12:58PM |
shadow651
orictosh
trevmas
It was always in my plan to upgrade to two colour printing at some stage so an option now might be a Duet 0.8.5 and something like an e3d Chimera.{/quote]
What would be useful is if Reprappro could provide a list of suppliers for individual parts as they are no longer in the game.
Yes, trying to source the machined quick set nozzle has been hard, so knowing where it's produced would help get some in the UK as I think it's made in china or India.
Some of the machined items popped up on a site which linked above and in Switzerland [www.robofun.ch]
I don't mind importing the items into the UK, as long as I'm able to meet the required MOQ and have funds available.
Having it in stock allows me to post it quickly. It's quite tricky get the pricing so it's fair and covers the costs involved.
orictosh
I would definitely be interested in getting at least a quick set nozzle upgrade kit, if not something simular to the RRP dual color upgrade for the O2's using a duet pre v0.85 (I assume you wouldn't stock the Duet shield or the Duex4 but I could source that from Think3DPrint3D).
I'm in the United States though, would your site sell to me?
Although maybe RRP will sell it's surplus (we can hope) - in which case I'd still need to order spare nozzles etc... from your site
Re: RepRapPro closing down January 08, 2016 02:34PM |
Re: RepRapPro closing down January 08, 2016 03:11PM |
Re: RepRapPro closing down January 08, 2016 04:07PM |
shadow651
Davek0974
orictosh
Davek0974
As a busines owner, I know there are many reasons for the sudden closure of a company, none of which I would like to post here as they are not good reasons. Almost every case of closure there is time to make an announcement, time to try and take every penny by selling off stock, time for employees to look for other work, many many opportunities that so far I do not see as being taken.
It is very odd indeed, especially with new products being launched etc.
I think this forum and its users deserves a full and frank statement from RRP at the least.
I would second this
Hi Dave,
Did some enquires about getting the quick-set nozzle engineered, company I approached weren't able to make them, as it uses stainless steel 316.
They suggested needing a small high precision sliding head lathe with back ops and that 316 is mostly used in medical applications.
Would you be able or know anyone that could produce the quick-set nozzle for Ormerod 2?
Chris
Hi
its a job beyond my abilities/setup i fear. 316 is not much fun to machine.
I can look around for a place but can't do it myself i'm afraid.
Where did you see that the nozzles are 316? All the schematics I could find for the one-piece nozzles and the quickset nozzles on GitHub say they are stainless steel and don't elaborate on the type.
Is there any reason 316 was chosen? what would happen if we used a different stainless steel?
Right now my O2 is running a single one-piece nozzle. I was planning to get the 2 color upgrade but I guess that's not going to happen. Although the Duex4 is available from think3dprint3d and now that they've fixed the noisy thermistor ground problem...... It's almost better than the expansion board RRP was selling anyways.
If I wanted to do that now I'd have to replace the entire hotend with something else, unless someone's going to be getting supplies of all of the parts unique to the O2(nozzles, tapered brass nuts, hot end blocks etc....)
And since so few of us would actually purchase anything but the nozzles..... I doubt that will be very economical.
I guess my O2 is probably going to stay the way it is, someday I'll have to get/build a different printer.
I feel bad for the people who just got kits, my O2 took a few months + 2 warranty claims on bad parts to get it operational; granted part of that was the shipping time to the US.
Re: RepRapPro closing down January 08, 2016 04:09PM |
tig124
shadow651
Davek0974
orictosh
Davek0974
I would second this
Hi Dave,
Chris
Hi
I might know someone who can precision machine Stainless steel parts (316 is better with heat than the other stainless steels, and also doesn't tarnish like other Stainless steels!), he works next door to me so if you can point me to the CAD files I could get him to price up a batch!
Re: RepRapPro closing down January 08, 2016 05:45PM |
Re: RepRapPro closing down January 08, 2016 06:11PM |
Re: RepRapPro closing down January 08, 2016 06:28PM |
tig124
shadow651
Davek0974
orictosh
Davek0974
I would second this
Hi Dave,
Chris
Hi
Re: RepRapPro closing down January 08, 2016 06:36PM |
Re: RepRapPro closing down January 08, 2016 06:44PM |
Re: RepRapPro closing down January 08, 2016 07:15PM |
shadow651
tig124
shadow651
Davek0974
orictosh
Davek0974
I would second this
Hi Dave,
Chris
Hi
Here is the PDF Schematic on GitHub:
[github.com]
This should be the solidworks model of the nozzle. But I don't have anything that can open it to verify that.
[github.com]
It would also be good if we could also get the following made - since they are all the hot end parts one would need for an 'upgrade' from one-piece. But we (the community that is) probably won't need as many of them as you shouldn't need to replace them unless something goes horribly wrong:
- Tapered Brass Nut - I can't find the schematics at the moment on GitHub. I've attached the pdf schematics for the old tapered nut for the one piece nozzles. As I recall the only difference is that the new nuts use M4x0.7 threads NOT M5 as this file states!. If anyone can find this file on GitHub that would be great
- Aluminum heating block - Again I can't seem to find this file, but it's just a hunk of aluminum with the M4x0.7 threads a hole for the heating cartridge and a hole for the thermistor. I know RRP had the hole very highly toleranced to the cartridges they supplied. If that's not possible we can do what many others do and have it clamp around the cartridge with a screw.
- Aluminum cooling block - Again, can't find the GitHub files. and I'm not as familiar with it.
- MDF spacer - this shouldn't be too difficult to get - again no files.
Not sure if any of the above are available elsewhere (except from the suppliers that RRP used). I suspect not because they are all unique to this hotend.
Pictures of most of this stuff can be found on the hot end assembly page. Since I'm not sure how much longer RRP's website will stay up I'm linking to a Jan 6th 2016 version of the page on the Internet Archive's website.
[web.archive.org]
If anyone is interested, the internet archive doesn't save most of the web automatically, but you can request it to save a page (one page at a time) I tried to save all of the O2's documentation and troubleshooting pages, I might have missed a few, and I didn't have time to add any of the other printers documentation.
Hopefully someone in RRP will see the earlier post about transferring ownership...... but if not I wanted to back up as much as possible. As RRP's documentation is/was stellar compared to most RepRap kits.
EDIT:
I see Chris beat me to it! But he did forget the Tapered nut and the MDF spacer
Re: RepRapPro closing down January 08, 2016 07:39PM |
