Re: RepRapPro closing down
January 08, 2016 11:52PM
0x0000
The MDF spacer is part #641, according to the CSV parts list. The DXF itself can be found here: [github.com]
If you're using an E3D hotend, you don't need it.
That's the right one. I printed it for my MK1 because the MDF one is broken.
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
January 09, 2016 12:45AM
Hi all,
but what about the Exruder? Don't forget this one. The hobbed insert is hard to get and when you get it the price is high. Somebody should recreate another one, based on common tiles, preferably the MK8 gear for example. And it is not because I got some here grinning smiley
I choosed them as it seems that these are the best choice for transporting filament.
Best regards,
Sven
January 09, 2016 01:19AM
Treito
Hi all,
Best regards,
Sven
I agree that they are somewhat expensive, I've just got some from think3Dprint3D because I got the DueX4 from them [www.think3dprint3d.com]
Not sure if they can be made any cheaper.... but I'm not even sure how or what they are made of probably stainless steel, unless they are zinc plated after hobbing which seems unlikely. I think hobbing is fairly labor intensive (everything else could probably be done on a metal lathe) - and again the tolerances on this are very tight
maybe someone with more machine shop experience can say.
Another reason they are expensive is I don't think there is a huge bulk demand.... Unless you're really cranking through filament or using something super abrasive - not sure you'd ever need to replace it. So if it's only £6.00 for one and you never replace it, it's not too bad, you'll probably pay at least twice that for the stepper driver.
I've seen some jigs on thingiverse for hobbing bolts like this one, although I think ideally you would also have the dremel tool held in the jig.
[www.thingiverse.com]
Edited 4 time(s). Last edit at 01/09/2016 01:25AM by shadow651.
January 09, 2016 01:56AM
I am telling that because I got mine here from the shop for about 6€ per piece and that was also some kind of expensive. They look like made of stainless steel. But as here is a big discussion about the nozzle we really should think of the hobbed insert. You cannot use a second nozzle or Extruder without that.
I guess that the amount of demanded pieces makes them that expensive and the common pieces like MK7 or MK8 are commonly produced so they are much cheaper.
January 09, 2016 02:24AM
I had to order mine from RRP's extruder kit. There are instructions for making a hobbed bolt on the RepRap wiki, which I would have attempted if I had the tools to do so. Obviously not as good as a commercially machined part, and I felt that the relatively low cost was worth the expense. It was definitely cheaper than all of the tools smiling smiley
January 09, 2016 03:29AM
Ok. Here you go.
PDF versions of the solidworks drawing for the Quickset hot end components and a quick drawing of the MDF spacer.
Personally I'm going down the E3D Chimera route and will try and post designs for my mount when I get it working well.
N
open | download - Quickset Bowden Start 106.pdf (31.2 KB)
open | download - MDF Heatsink Spacer 743.pdf (16.6 KB)
open | download - Quickset dual colour cooling block 736.pdf (35.7 KB)
open | download - Quickset Heater Block 739.pdf (29.7 KB)
open | download - Quickset Nozzle 0.3mm 737.pdf (36.3 KB)
open | download - Quickset Nozzle 0.5mm 738.pdf (34.3 KB)
open | download - Quickset Tapered Nut 794.pdf (28.3 KB)
January 09, 2016 04:49AM
0x0000
That one will not work with the standard Extruder. That is why I choose the original hobbed insert for my own Ormerod clone. But at that time I only found not much vendors. Mostly demanded more than 10€ others demanded more than 20€! So it would be a good idea to consider a redesign.
January 09, 2016 07:38AM
I am very sorry to see RepRapPro closing down. Also feel very sorry for Ian that he is redundant.My best wishes to Ian for a new job.
January 09, 2016 12:50PM
This is very sad all the way around. I have been very impressed with the engineering of their products and the level of service and support provided.
I inquired about the temperature limitations of the QuickSet hot end shortly after it was introduced and was told the primary limitation is the thermistor being used, which is good to 300C. With alternate temperature-measurement provisions, they reported promising FEA results up to 500C, though the cooling block would go to 50C and the assembly might be radiating enough heat to be problematic to surrounding structure at that point.
As far as spares, one of the nice things about the construction of these machines is that they are totally modular and it is a piece of cake to make modified RP parts to adapt parts. Given a compatible mounting and interface with the bowden tube, extruder drives and hot ends are pretty much plug-and-play.
That said, the RRP extruder drive is great in providing the function of an expensive geared stepper with an inexpensive standard stepper in a compact package and I also really like the tongue-and-groove attachment of the top end of the Bowden tube. With a different bearing on the large gear, an M5 screw with a flat milled on one side of the shaft, an M5 washer and nut, and dimensional modifications to the drive block and large gear as necessary, the $9 hobbed drive roller from SeeMeCNC could be adapted into the RRP extruder drive, probably less-expensively than a small run of custom hobbed drive gears. The grooved brass fitting doesn't strike me as something that would be exceptionally difficult to machine, but it still might be cheaper to adapt the drive block for a PTC when people no longer have spares.
The low thermal mass, temperature capability, and height adjustability of the QuickSet are also exceptional. I would have to do some digging to see if I could find a commercially-available nozzle that could be adapted into this assembly.
January 09, 2016 02:05PM
Think3DPrint3D uses the same hobbed insert on their Mini Kossel extruder I believe, so I expect the hobbed insert will continue to be available from them.
I used pneumatic connectors on my extruders for a while, but I found they lost their grip after a few insertions and removals of the PTFE tube, so I had to replace them. After a few replacements, the thread in the extruder drive wore and would no longer hold the connector against the force of the filament. Another pneumatic connector lost one of its metal teeth, which found its way into the hot end of my Kossel and wrecked it. So I reverted to the brass end and locking tongue.
January 09, 2016 07:56PM
Sad news, I'm just getting comfortable with my Ormerod 2. Quality printer, reliable prints and I was just considering getting a dual extruder. Darn...
droftarts
Sorry about this, everyone, and thanks for all your support over the years.
I was made redundant on 11th December. I've stayed away from the forums since then to avoid any embarrassing questions, until there was an official announcement. I'll help out where I can, though I don't actually own an Omerod! I do have a Fisher, though, and might be able to have the Tall-merod at some point.
Anyone want to employ a technical support engineer?! Any (helpful) suggestions gratefully received!
Ian
ex-RepRapPro tech support
Ian, you have nothing to apologise about, as it wasn't in your control. Add to that your immense assistance with the forums and myself, RRP were lucky to have you.
Regarding employment, you have a large amount of experience and expertise in the field of 3D printing. As it's a young field, if you can find another 3D printing company with the right fit, then IMHO you may get regarded as a bit of a star applicant (You can even point to the forums here as some evidence of the quality of your work and customer service.)
Or perhaps even start your own RRP based offshoot? You have a reputation already, which is useful headstart. (If you decide to go down that route, I'll be happy to provide any advice and assistance as a small business owner in your area, feel free to contact me - I'll buy you lunch anytime! smiling smiley )
Lastly, and talking to the forum in general - would it be worth getting a page on reprap.org detailing alternate sources for various parts? If that isn't possible (advertising rules or whatever), then perhaps a separate endeavour by RRP printer (or more specifically Ormerod 2) owners could prove rather useful?... e.g. a Google spreadsheet or some other collaborative measure (perhaps even a stickied post)
January 09, 2016 11:43PM
dc42
T3P3 unfortunately is very expensive. This may be caused because it is a small company, but 6 GBP for a hobbed insert? I earlier paid only about 60% of this price probably less for one. And there are only a few shops whose have this in stock and some of them are even more expensive. That is why I am considering to use standard components. In my eyes it would be indeed a better way to use standard components as the Ormerod is spreaded world wide and not every country can get such kind of parts. Think about those persons. This is much more important than the price. (I even would pay such a high price for a hobbed insert as it is only one time for a dual nozzle upgrade which costs much more so this little costs are not much noticeable).
@cheeseandham: I do not think that there would be a problem to reserve a page where you can get parts. These pages already exists at the wiki for the heated beds or for the common hobbed inserts for example.
January 10, 2016 12:14AM
Treito
I've got my finger on the order button for a Duet 0.8.5 on T3P3, but I'm going to have a think about it before placing my order. I do like the Duet and think it's well worth the money, but I've seen so many complaints about its reliability (including my own failed board). There are now only three suppliers for Duet boards in the entire world (Robofun, Replikeo and T3P3... correct me if there are more) - will any more pop up, or will these vendors stop carrying it due to the high failure rate? I think it's very important to come up with alternative ways to drive the printer, such as a basic RAMPS kit off eBay. I've been looking at the RAMBO in particular, as a lot of the wiring for the stepper motors, heated bed, and hotend cartridge looks to be interchangeable with the Duet... the proximity sensor might be an issue, and I'm not sure of the power supply requirements! I believe I've seen someone on the forum claiming to use RAMPS before, but I've not seen a documented approach to getting it running on an Ormerod. In particular, I would be really keen to see how it's commissioned and calibrated.
I'll keep an eye out. I have a mechanically complete printer, but no electronic brain to drive it! I'm keen to experiment and don't have many options with a dead Duet.
Edited 2 time(s). Last edit at 01/10/2016 12:17AM by 0x0000.
January 10, 2016 12:19AM
You could use other controllers like RAMPS with the Ormerod. Why you have not seen any report? Nobody would do that because you only will have disadvantages. It is harder to setup, a web-interface is not easy to get and they are as well problematic like the Duet.
I am unsure if I will buy a Duet 0.85 for my new printer design. It will be of Dual nozzle support. I have a spare Duet 0.6 here and also a Duet shield, but this was mainly intended for my Ormerod 2.
January 10, 2016 12:43AM
Treito
I might have to be that guy, if I want to see it smiling smiley
January 10, 2016 01:43AM
Good luck. You may have the advantage if something is broken you only have to exchange some parts of your controller items but you will also need a voltmeter and a screw to setup the motor currents instead of a connection, a keyboard and an editor. tongue sticking out smiley
January 10, 2016 03:29AM
Treito
dc42
£6 for a hobbed insert is not a bad price, if I had the equipment to make them it would most likely be the same or more. The only way to reduce price is to have a massive batch of hundreds or a thousand or so made on automated machinery - then you are stuck with a mass of inserts and a relatively small market.
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
January 10, 2016 03:33AM
0x0000
I've got my finger on the order button for a Duet 0.8.5 on T3P3, but I'm going to have a think about it before placing my order. I do like the Duet and think it's well worth the money, but I've seen so many complaints about its reliability (including my own failed board.
Is the Duet failure rate high? There must have been many thousands of Duets shipped and we haven't heard of many failures. Those with L7 blown must be the result of shorts or miswiring - on the Duet 0.6 it doesn't help that the hot end heater connections are right next to the thermistor connections. Some of them are Replikeo boards, and from feedback on other forums we know that quality management on the Replikeo boards leaves something to be desired. There remain a few instances of boards with overheating microcontrollers but with L7 intact. I am intrigued by the suggestion that some of these might be caused by a faulty SD card, and I have been in touch with T3P3 regarding how to protect the microcontroller from that.
In the Arduino/RAMPS ecosystem there are frequent reports of issues with overheating voltage regulators, overheating bed mosfets, burned out power connectors, and failed drivers (probably because the PCB area is far too small to cool the chip properly and it is hard to set the correct motor current).
The problem with "standard parts" is that all too often they have design flaws that don't get addressed (as in Arduino/RAMPS), and they are often only cheap because the manufacturing is of poor quality.
January 10, 2016 03:34AM
Hello Dave,
the point is that I have paid less here at the shop and most important is the availability. Here are many users which could not obtain this part as it will not be delivered to their country. What about them? Do we really need parts for a bunch of printers? Is there a problem with the MK( hobbed insert? I understand as the printer was designed that the MK7 or the bolt hobbed insert would not have been suitable for our printers, but now the MK8 is nearly about the same size.
January 10, 2016 03:37AM
dc42
You say that my SD card may have been the cause for my second blow out?! How is that possible?
January 10, 2016 03:44AM
The SD card pins are connected directly to the mcu pins, as on Atmel's evaluation boards. If the SD card has a short between an I/O pin and Vcc or ground, that will draw excess current from the pin and is likely to overheat and damage the mcu.
January 10, 2016 03:49AM
Two questions:
Was that the reason why one Duet board of mine was broken? Or even both? Even though the SD-card was working well at my PC? Meanwhile I luckily exchanged the card with a faster one, but it would be important to know for me. Couldn't you use the internal temperature sensor for monitoring the MCU temperature to shut it down?
Edit: Sorry I can only count to two and not to four. grinning smiley
Edited 1 time(s). Last edit at 01/10/2016 03:50AM by Treito.
January 10, 2016 04:10AM
Treito
Two questions:
Sorry, I still don't know why your boards failed. Using the internal temperature sensor is a good idea - I'll add it to my list of firmware improvements to make.
Treito
Nobody expects the Spanish Inquisition! [Non-Brits, see [www.youtube.com]].
January 10, 2016 04:18AM
No problem, but as far as I know I used the same SD-card for both failed boards, but I am not sure as one time the filesystem was damaged.That means that it has to be at least two different cards if I reflect this. Maybe there is even more we should talk about, but not in public. First I would like to know what happens after a SD-card destroyed a board. Can these boards still boot? What is not working anymore? What is still working?
January 10, 2016 05:13AM
The only evidence I am aware of for an SD card destroying a board is this note at [reprappro.com]:
"Is the main ARM processor getting warm/hot? We’ve had a couple of people report that the SD card has shorted out the processor, due to manufacturing defects. Unfortunately, this is usually terminal.".
If the SD card is shorting out the processor, then it might damage the whole processor, or just the SD card interface pins. If it's just the SD card interface pins, then if the SD card is removed, it should be possible to connect to the printer over USB. The firmware used to need to execute an M555 P2 command in config.g to put it in Marlin emulation mode before it would respond to Pronterface, but in recent versions of my fork I have made Marlin emulation the default.
January 10, 2016 06:18AM
Treito
Hi all,
but what about the Extruder? Don't forget this one. The hobbed insert is hard to get and when you get it the price is high. Somebody should recreate another one, based on common tiles, preferably the MK8 gear for example. And it is not because I got some here grinning smiley
I choose them as it seems that these are the best choice for transporting filament.
Best regards,
Sven
hobbed-insert.PDF
I have attached the hobbed-insert drawing, found it the tags view of RRP Ormerod git hub as 528.4, within a folder called pdf, the Bowen brass ends and start drawings are in there also. The main reason that they are expensive or vendors demand high prices, is due to the lack of them and the manufacturer needing the equipment and skills to automate the process so that you ship large numbers of them. The machine shop also needs to cover their overheads say of about £250/day so doing small amounts of one item becomes expensive, if the job is complex or needs human invention that can push up the cost.
Davek0974 the person who makes the very good Aluminium x-rib has given an example of this by stated that needs 6 orders before starting the machine so it's worth the cost of running it.
Using the wayback machine RRP sold their ones for £4.17 . So they must have be buying loads of them, but of course there is one in every kit.
That together with some M3 x 30 hex bolts, 2 M3 nyloc nuts, bearings maybe a washer makes a superior feeding mechanism for filament compared to the hobbed bolt.
Edited 1 time(s). Last edit at 01/10/2016 06:22AM by orictosh.
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
January 11, 2016 02:21AM
Just saw this post. Ian i am very sorry to hear the news. I think and wish on the other hand that u ll find ur way ( if you didn't do already) . You helped me a lot with my mendel and ur knowledge and speed are admirable. About the nozzle guys my personal opinion is that it is something that can be done easy if you have the tools. Back in December i broke my nozzle on my way to find the cause of my continuous clogs. The one thing i have found that it would make it better was to make this taller. So first i started to ask some metal lathe spots and workers. When i ve found them difficult to deal with this small quantity as ( i ve given them wrong infos saying it has to be treated for more smoothing) i bought some 304 bolts 50mm and i said i ll do it with what i have.
I managed to go around 2mm in the bolt with the .3mmdrill and a dremel chuck then from 2mm-4mm with a .5mm drill and then up to 7 with the 0.7 drill . I did this in an old bench drill but with top quality lubricant for stainless steel and in a 2 hours preparation - work - inspection time.
I did all this in a 4mm screw which it wasn't the best solution as it had to be wider to fit the bowden tube. Finally i broke the .7 drill and stopped ( funny i broke the strongest one ) . Anyway now i tried from the beginning the .7drill i went 5-8mm deep.
I think it is not difficult all the parts and spares to be made by people with knowledge and equipment but i liked the rpp to be around 3d printing the way it was.
For once more sorry to hear that news Ian.
Edited 1 time(s). Last edit at 01/11/2016 09:23AM by Gaou.
January 11, 2016 08:31AM
Hi everyone
Many thanks for your support! It really does make a great difference to me.
I should also point out that, while I was one of the few 'public-facing' members of the RRP team, there were more of us, and I feel equally badly that they lost their jobs at the same time as me; Joe (who worked for RRP for even longer than me, in production, mainly packing kits), Tom (production, made all the wiring looms and packed kits) and Chris (junior mechanical engineer/designer). There are also the three directors; Sally (who many of you know through sales/admin), Jean-Marc (managing director and head mechanical engineer) and Adrian (engineering R&D, and figurehead!). While Adrian is comfortable in his retirement, the other two still need to put food on the table! We also had a round of lay-offs earlier in the year - Claire (production manager), Joe '90' (ran the production of printed parts), Brad (production), Mark (who did a bit of everything) and, latterly, Nathan (production). I miss working with all these unique people, for the imagination, shared vision and just the general banter and fun we had, and wanted to list them so everyone appreciates the full team that was behind RRP.
I'll leave it to Adrian to explain the reasons for RRP's eventual closure, but my feeling is that the market for 3D printers has moved on from it's DIY roots. The competition from cheap foreign manufacturers, who sell complete printers for the same cost as a kit, and kits very cheaply, is the main factor. Unfortunately, it's only later that customers realise that they don't have the support they need to run a complex piece of machinery. RRP are not the only manufacturer to retreat from the consumer market; even the biggest, Makerbot and 3D Systems, have retrenched. And, perhaps, that 'Consumer 3D printing' has entered the 'Trough of disillusionment' in the 'emerging technologies hype curve'!
Regarding spare parts, and particularly the machined parts, Jean-Marc has always run a separate reprap market-place site [www.emakershop.com]
My understanding is that he will sell RRP-specific parts (nozzles, hobbed inserts etc) through this site. There is some stock left over from RRP, and he knows where to get parts manufactured; as with much of the RRP supply chain, I'm unfortunately not at liberty to reveal our suppliers. The drawings and specifications are available, if you want to get the parts manufactured elsewhere, and other companies like RepRapPro China and Replikeo may be able to supply parts too, so hopefully people won't get left in the lurch too much. You can always contact me through the forums if you need help, and I'll try and point you in the right direction.
Ian
January 11, 2016 08:55AM
As idle musing, I wonder whether it would be possible to use the jet for a paraffin or gas stove as a nozzle?
Dave
January 11, 2016 09:33AM
droftarts
Hi everyone
Ian
i thought i wrote it but i didn't. That was exactly what i was thinking writing down to sally about the news. RPP are humans. And these people in my opinion was just driving the car of 3d printing.
Anyway there aren't much to say.
Dave i think it would . but this nozzle were something i liked it a lot . Only if it was a little taller. Anyway we ll see how it will go.
