E3D and spring loaded extruder January 09, 2016 05:09AM |
Re: E3D and spring loaded extruder January 09, 2016 05:29AM |
Re: E3D and spring loaded extruder January 09, 2016 07:11AM |
Re: E3D and spring loaded extruder January 09, 2016 07:18AM |
Darathy
I am guessing u bought hot end for 3mm fillament instead of 1.75 by mistake
appjaws1
I have a cheap E3D hot end from eBay and want to fit the supplied fitting to the adjustable extruder.
The push fitting seems rather large.
Do I need a smaller fitting or has anybody modified the extruder to take this fitting.
The other alternative is to remove the push fitting and use the reprap brass end on to the tubing.
Re: E3D and spring loaded extruder January 09, 2016 07:50AM |
Re: E3D and spring loaded extruder January 09, 2016 07:52AM |
Re: E3D and spring loaded extruder January 09, 2016 07:55AM |
appjaws1
Sorry for the confusion.
I have the correct E3D for 1.75mm filament.
The problem is that the end of the PTFE tube that attaches to the extruder has a pneumatic fitting with a screw thread of 9.5mm diameter. How is this attached to the extruder, which would need a hole to take a tap for this size of thread?
[attachment 69303 E3D.jpg]
I assume that a smaller push fitting is available, if so what should I be looking for and what is the best way to attach the PTFE tubing to the extruder part?
Thanks for any help.
Re: E3D and spring loaded extruder January 09, 2016 08:01AM |
¸Quote
appjaws1
Re: E3D and spring loaded extruder January 09, 2016 08:05AM |
Treito
@Darathy At this offers you have to tell the seller what kind of hot-end do you want. That means nozzle size and filament size. Otherwise you get a standard one like I have (1.75mm filament size with 0.4mm nozzle size) or sometimes you get a random one! BTW what about your heater cartridge? is it 25W or 40W? That is one reason I did not buy the original one.
Re: E3D and spring loaded extruder January 09, 2016 08:09AM |
cua193
I assume you're using the standard sprung extruder.
The brass unions supplied are a strange1/8" thread which is 9.3mm. the fitting can be fitted with brute force and ignorance, use a drill or filament to keep the union square with the arm.
I've attached a file for the arm and for the fixed part which has had the very weak and breakable parts designed out.
Both parts have to be trimmed after printing.
I've also redesigned other parts to strengthen them & get rid of countersunk screws, every one of which failed on my Ormerod 1.
Richard
Re: E3D and spring loaded extruder January 09, 2016 08:10AM |
Darathy
Treito
I got a 25W one and heats up slow as hell ,i have removed my E3D since the Original is faster and does produce better prints for me atleast so i have the E3D just laying araund atm till it breaks and since reprappro is gone i will use it then
Re: E3D and spring loaded extruder January 09, 2016 08:17AM |
Darathy
You never got any blobing issues with your fake? or Problems with circles where the fillament would not stick and just make a line across the hole?
Re: E3D and spring loaded extruder January 09, 2016 08:38AM |
Treito
Darathy
Treito
Your post prevented me at least from buying the original one. I read your statement earlier. So I gave the clones a try. They are equipped with a 40W heater which is fast enough in my eyes. With the 0.4mm nozzle I even got better prints compared to the original nozzle of my Ormerod 1 (the good old one, not quickset).
Re: E3D and spring loaded extruder January 09, 2016 08:44AM |
appjaws1
Re: E3D and spring loaded extruder January 09, 2016 08:47AM |
appjaws1
Printing your parts now thank you
Paul
Re: E3D and spring loaded extruder January 09, 2016 11:13AM |
Re: E3D and spring loaded extruder January 09, 2016 11:52AM |
Re: E3D and spring loaded extruder January 09, 2016 11:53AM |
Re: E3D and spring loaded extruder January 09, 2016 12:10PM |
Re: E3D and spring loaded extruder January 09, 2016 03:32PM |
Re: E3D and spring loaded extruder January 10, 2016 08:23AM |
appjaws
yes please,
I have just printed Richards version and am unable to clear the hole for the fitting and the support between the lugs where the motor part swings.
Re: E3D and spring loaded extruder January 10, 2016 11:47AM |
Re: E3D and spring loaded extruder January 10, 2016 11:51AM |
