Filament slips January 12, 2016 01:06PM |
Re: Filament slips January 12, 2016 01:36PM |
kpapr1
1) Removed bowden tube from the Quick-set nozzle, heated up the nozzle and tried manually to extrude some filament.
Re: Filament slips January 12, 2016 01:44PM |
Re: Filament slips January 12, 2016 02:39PM |
Re: Filament slips January 12, 2016 02:42PM |
Re: Filament slips January 12, 2016 02:54PM |
Re: Filament slips January 13, 2016 02:11PM |
Re: Filament slips January 15, 2016 03:22PM |
Re: Filament slips January 15, 2016 03:35PM |
Re: Filament slips January 15, 2016 03:39PM |
Re: Filament slips January 15, 2016 03:44PM |
Re: Filament slips January 15, 2016 03:49PM |
Re: Filament slips January 15, 2016 04:21PM |
Re: Filament slips January 15, 2016 04:29PM |
Re: Filament slips January 16, 2016 07:30AM |
Re: Filament slips January 16, 2016 07:37AM |
Re: Filament slips January 16, 2016 07:42AM |
Re: Filament slips January 16, 2016 08:48AM |
Re: Filament slips January 16, 2016 09:32AM |
Treito
Do you use 4 or 5 probe positions?
BTW it is also a good idea to include the skirt at your pictures.
Re: Filament slips January 16, 2016 09:36AM |
Re: Filament slips January 16, 2016 10:00AM |
Re: Filament slips January 16, 2016 10:03AM |
Re: Filament slips January 16, 2016 10:05AM |
Re: Filament slips January 16, 2016 10:19AM |
Re: Filament slips January 16, 2016 10:23AM |
kpapr1
I haven't tried without bed compensation, I will do so now and report back...
Re: Filament slips January 16, 2016 10:26AM |
Re: Filament slips January 16, 2016 10:28AM |
Re: Filament slips January 16, 2016 10:40AM |
kpapr1
.. Also there's no bump on the glass maybe a small gap from the kapton tape but no overlap..
dc42
When I looked into this a few months ago, I discovered there were two causes of this issue:
1. A very slight doming of the glass, because it is clamped at the corners. This effect is small, perhaps 0.05 to 0.1mm. Using 4mm glass instead of 3mm instead should reduce it by more than half.
2. The main contribution is the hot end angle varying along the x-axis. One cause of this is the varying sideways force exerted by the Bowden tube on the hot end, which pushes the hot end sideways and the nozzle down harder in the middle of the x-axis than at the ends. Another cause can be a wave in the acrylic x-plate.
I've been wondering whether it would be worth implementing 5-point bed compensation (i.e. 4 corners + the middle) or 9-point (4 corners, 4 edges + middle) in the firmware, which is a possibility when using a z-probe that works anywhere on the bed, such as my differential IR board.
Re: Filament slips January 16, 2016 10:51AM |
Re: Filament slips January 16, 2016 11:24AM |
