Any tips on putting heated bed together January 13, 2016 12:42AM |
Re: Any tips on putting heated bed together January 13, 2016 03:58AM |
Re: Any tips on putting heated bed together January 13, 2016 07:24AM |
Re: Any tips on putting heated bed together January 13, 2016 08:12AM |
orictosh
If you have the aluminium heat spreader, spend some time with emery paper removing the high spots and burrs on the faces and edges of the plate.
Also before powering check for shorts between plate and PCB heat bed using a multimeter.
I stupidly didn't spend much cleaning the Aluminium plate and placed 3 holes in the PCB heat bed, which I needed to cover with kapton tape so the heat bed didn't short to the metal plate.
Re: Any tips on putting heated bed together January 14, 2016 01:55AM |
Darathy
orictosh
So i am not the only one who has done this xD
Re: Any tips on putting heated bed together January 14, 2016 08:38AM |
