New RepRapFirmware release 1.09r-dc42 January 16, 2016 06:38PM |
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 02:10AM |
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 02:22AM |
Fpex
What is a thermostatic fan?
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 03:26AM |
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 06:32AM |
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 06:35AM |
fotomas
Does this release contain the experimental feature I read about somewhere. Gradually slowing down the extrution prior to a layer change? To avoid the blib that usually occurs at a layer change.
Maybe I have understood it completely wrong....?
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 10:32AM |
dc42
Fpex
It means that if you have an unused controlled fan output on your Duet, you can use it to turn the hot end fan off when the hot end is cool enough not to need the fan running - just like my hot end board does.
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 12:54PM |
appjaws1
Quite some time a go, I shorted the fan connection on your single hot end board and connected a wire to by pass the electronic switch. The result was that I have been able to use the board but the fan stays on all the time.
appjaws1
Is it possible to use a different connection on the original duet and use the new feature to set the temperature cutoff?
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 05:26PM |
Re: New RepRapFirmware release 1.09r-dc42 January 17, 2016 06:56PM |
unstable
dc42: Does this firmware version fix the cold extrusion bug?
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 04:14AM |
dc42
appjaws1
If you mean that you burned out the fan mosfet, then if you replace it and remove the diode (which I no longer fit in more recent versions), it should work again. I can send you a new mosfet if you like.
this is the damage, the track was destroyed.
appjaws1
If you do not have a print cooling fan connected to the FAN0 output, then yes. You will need to put M106 P0 T45 H1 in config.g (or H1:2 if you have 2 nozzles). Caution: the fan will be off until config.g is executed.
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 04:21AM |
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 05:59AM |
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 11:35AM |
Sardi
Im still at firmware 0.74 because I print a lot of small, curvy things like texts etc. Is the jerking moves issue resolved by now?
The last update I tried was 1.03 + web interface, but it didnt print my models nicely as it would "stop and go" on almost every curve.
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 04:37PM |
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 04:58PM |
Re: New RepRapFirmware release 1.09r-dc42 January 18, 2016 06:33PM |
Re: New RepRapFirmware release 1.09r-dc42 January 19, 2016 06:47AM |
dc42
That said, there is a bug in Cura that causes it to output very short non-extruding moves between extruding moves sometimes. If you are using Cura, that could be the source of the problem you encountered.
Re: New RepRapFirmware release 1.09r-dc42 January 19, 2016 07:37AM |
dc42
Actually it's not additional processing that causes the issue, it's that the newer firmware honours the X and Y maximum jerk speeds. On the old firmware, these were also the minimum print speeds, so they had to be set very low if you wanted a low first later speed. With the newer firmware, you need to use higher values to allow cornering at reasonable speeds.
Re: New RepRapFirmware release 1.09r-dc42 January 19, 2016 03:38PM |
Re: New RepRapFirmware release 1.09r-dc42 January 19, 2016 05:45PM |
Re: New RepRapFirmware release 1.09r-dc42 January 20, 2016 08:54AM |
Re: New RepRapFirmware release 1.09r-dc42 January 20, 2016 02:56PM |
kpapr1
Are there any changes needed in the config.g going from dc42m to dc42r ?
Re: New RepRapFirmware release 1.09r-dc42 January 20, 2016 06:01PM |
Re: New RepRapFirmware release 1.09r-dc42 January 20, 2016 06:11PM |
Re: New RepRapFirmware release 1.09r-dc42 January 21, 2016 11:15AM |
Re: New RepRapFirmware release 1.09r-dc42 January 21, 2016 02:49PM |
Re: New RepRapFirmware release 1.09r-dc42 January 21, 2016 09:50PM |
Re: New RepRapFirmware release 1.09r-dc42 January 23, 2016 08:15AM |
Re: New RepRapFirmware release 1.09r-dc42 January 23, 2016 09:13AM |
rjmusto
Thanks dc42 for the update. I have flashed it today.
Got one problem; there are no temperatures or positions reported via the web interface. I can control the temperatures, but am not getting any reports. Pronterface is showing temperatures ok. And the printer itself seems ok: I have set it off on a simple print and it looks ok.
I've updated the config.g file to the latest one on dc42's SD-image folder, just in case something was out of sync here, but hasn't fixed it.
Any suggestions?
Thanks,
Ralph
