Re: Ormerod suddenly stops mid print November 08, 2016 03:39PM |
Re: Ormerod suddenly stops mid print November 08, 2016 06:01PM |
dmould
There is also an issue if you switch anything that is on the same power plug. For example when I first used my Ormerod it was plugged into an extension lead - if I plugged a soldering iron into another socket on the same extension lead, the Duet would crash. So ensure that your Ormerod is the only device connected to the wall socket. Maybe try using an extension lead that has surge protection in case it is cause by something else in your home (e.g. fridge or washing machine cycling). e.g. [www.amazon.co.uk]
Dave
Re: Ormerod suddenly stops mid print January 04, 2017 06:18PM |
Re: Ormerod suddenly stops mid print January 05, 2017 03:37AM |
Re: Ormerod suddenly stops mid print January 05, 2017 04:01AM |
Re: Ormerod suddenly stops mid print January 05, 2017 07:26AM |
Re: Ormerod suddenly stops mid print January 05, 2017 10:58AM |
A hard fault is an exception that occurs because of an error during exception processing, or because an exception cannot be managed by any other exception mechanism. Hard faults have a fixed priority of -1, meaning they have higher priority than any exception with configurable priority.
Re: Ormerod suddenly stops mid print January 06, 2017 06:24AM |
Re: Ormerod suddenly stops mid print January 06, 2017 05:02PM |
Re: Ormerod suddenly stops mid print January 15, 2017 04:57PM |
Re: Ormerod suddenly stops mid print January 16, 2017 02:42PM |
Re: Ormerod suddenly stops mid print February 18, 2017 10:52PM |
Re: Ormerod suddenly stops mid print February 19, 2017 04:29AM |
