Ormerod 2 bed sensor
Posted by Europa
Re: Ormerod 2 bed sensor
February 07, 2016 06:22PM
Treito, the board dimensions are on dc42's site. 24mm wide X 18mm high.
Brian
February 07, 2016 08:14PM
There was that 18. I would also have to relook the hole positions and the placement of the IR-LEDs.
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
February 08, 2016 02:28AM
You can find the dimensions of the mini board except the height at the end of the fitting instructions at [miscsolutions.wordpress.com]
Edited 1 time(s). Last edit at 02/08/2016 02:29AM by dc42.
February 08, 2016 05:08AM
Treito no problem if you don't have a STEP file, I will design my own version of the E3D mount with provision for the mini sensor, that way I can remove the extra bits which are not necessary such as the mount posts for the large sensor, LED mount etc..
ATB
Brian
February 08, 2016 05:35AM
I can give you a step file as well as the FreeCAD file. That's why I asked what you would prefer.
February 08, 2016 05:39AM
dc42
Thanks I found it already, but where is the position of the LEDs? I would prefer to hit the sensor board in the middle.
Brian I am wondering if it's necessary to make both a mounting option? I would provide a small part for the existing mountings. Also for the Ormerod 1.
February 08, 2016 06:17AM
Hi Treito, just a STEP file will do.
If you enlarge the image you can see the two IR projecting LEDs to the right and the receiver to the left of centre so that the detection point is in the middle of the board.
Brian
February 08, 2016 06:41AM
Okay I can provide it when I am at home later. I made a different PCB design where I assumed the sensor positions so I will take this. I would have preferred to verify the positions, but never mind.
February 08, 2016 11:57AM
So I provided the step-files as requested. I took a short look on how to make a small piece to mount the sensor board without changing the nozzle mounting itself. However I am a little bit afraid of the condenser so I wouldn't be good to do a quick and dirty design. Even though I guess only something about 1000mm material will be needed only I would prefer to do a good quality design or at least two as I need a slightly other design for the One-piece-fanduct designed by the master himself: dc42. Luckily it seems that both designs would be good with the same height so there would be only a difference in Y-direction. So I would like to print a model of the board itself first (outer dimensions, holes and condenser) to be sure that the condenser is not hitting the M5-rod.
@dc42 can you please tell me how deep is your condenser? I would guess something about 11mm? Do you provide a mounting bracket for your big sensor boards for the quick-set of the Ormerod 2? Do I need a black paper underneath a PrintBite surface?
open | download - Hot-end-fan-part-1.2.step (552.4 KB)
open | download - Hot-end-carriage-part-1.2.step (399.3 KB)
February 08, 2016 12:51PM
Many thanks Treito, much appreciated.
By the way what do you think of Printbite ?
Brian
February 08, 2016 02:47PM
Sorry we've just moved and the IR boards are still packed.up. I think the capacitor is about 8mm tall. Add 1.2mm for the PCB to get the total height.
The sensor works well on PrintBite, no backing needed.
February 08, 2016 03:48PM
I know that you are moving. I am also thinking if the capacitor should head to the nozzle or to the sensor pad. I think that the last option would be better.
February 08, 2016 04:38PM
I suggest mounting the board with the back just a few mm from the heater block and the capacitor towards the sensor pad.
February 08, 2016 05:59PM
I have a geckotek on order for my ormerod2 so I'm very interested!
As it uses a steel plate, I was planning to use a cheap ps-05n inductive sensor. I use them on my cnc router and they are very reliable.
Am I missing something here?
February 09, 2016 12:47AM
You are welcome Brian.
I cannot live or at least print without PrintBite. grinning smiley However to be fair there are rumours at the German FB groups (and I think they are true) that PrintBite is some sorft of a ordinary FR4 piece. However PrintBite is equipped with a special pattern on the surface and the ordinary FR4 needs to be sanded before you can use it and the PrintBite gives you a pattern..
@dc42 Like I thought, many thanks for the answer. However my Ormerod 1 uses your one piece fan duct. I will check it with a later model if there is enough space to place the PCB underneath your mounting holes. I would do this also for my own design. That would give me the possibility to move the PCB back a little bit. Can you send me an offer to pay via Paypal or will this be done if the batch is ready?
February 09, 2016 03:29AM
Surely mounting the mini sensor in front of the heater block will not put it in a position where it can move over the pad for homing the X axis?
Brian
February 09, 2016 03:33AM
Hello Brian,
you have to mount it on the side where I already prepared the mountings for the big sensor board. In a few days I would either prepare a mounting bracket for my holder or I will do a new one.
Best regards,
Sven
February 09, 2016 03:36AM
Hi GroundAttack,
The Geckotec build plates are very good, if anything they are too good. I have trouble removing ABS prints and have needed to slip a knife under them which of course risks damaging the surface, also the nozzle height above the bed is critical, you will need to get that as accurate as possible. I certainly don't mean to put you off buying one though, I have the HT model and love it.
February 09, 2016 04:21AM
Treito, I came across the accurate dimensions on dc42s site for the mini sensor board including mounting hole spacing, see below.
If the bottom left corner of the board is position (0, 0) then other points on the board are at the following (X, Y) coordinates, in mm:
Top right corner (24.0, 17.62)
Mounting hole centres (2.70, 14.92) and (21.11, 14.92)
Mounting hole diameter 2.8
Brian
February 09, 2016 07:42AM
Brian, thanks. I already found them, but like I said some circumstances are not clear for me. I don't want to design something without knowing if it works. For example if I displace the part the condenser may hit the threaded rod. Or I am not sure if the PCB board really fits underneath my mountings on the nozzle holder. Theoretically it should work do I could place the PCB directly nearby the nozzle, but it would be s tight fit. So I would prefer to print a simply model first to be sure that it fits. As there is still plenty of time for the designing because the batch will not be ready I would take a little bit more time for it to get a good design and not a design that works somehow.
