New Ormerod defective heater
Posted by lvperlo
February 07, 2016 09:54AM
My new Ormerod2 arrived with a defective nozzle heater.
Since the printer is useless now and Reprap closed down, where can I get a replacement?
Best regards
Leon
Re: New Ormerod defective heater
February 07, 2016 10:24AM
Please check if you have a heater with a diameter of 5mm or 6mm. The 5mm variants are hard to get. If you have no luck at ebay or Amazon there are available at Replikeo. Watch out for the version you choose.
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
February 07, 2016 11:21AM
You can get them on emaker website as well
February 07, 2016 12:43PM
Just taken a look on e-maker and my site [www.3dprintandstuff.co.uk]
E-maker has the 5mm diameter ones [www.emakershop.com]
More like the one in the kit
Where as I have the 6mm ones with the long cable
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
February 08, 2016 12:36AM
Replikeo still have them in stock also: [www.replikeo.com]
Try contacting reprappro anyway, I've had a few things go wrong on mine since they closed and they've still responded and helped out.
February 08, 2016 02:24PM
orictosh
i keep forgetting you have a store, i have it book marked as well spinning smiley sticking its tongue out
Edited 1 time(s). Last edit at 02/08/2016 02:24PM by steve0-uk.
February 21, 2016 03:07PM
Ok, Got a new one from e-maker and some other spare parts, while they are still around .
Problem solved .. .well at least this one.
Thanks
Leon
